  1. Lynn Hayner
    Lynn Hayner New Member
    My 2005 Prius' headlamps are pointing down. What do you call that part located near the rear left wheel that levels them?
  2. Tideland Prius
    16,195
    *Moved to Gen II Troubleshooting*
  3. Tideland Prius
    16,195
    I'm not sure which country you're in but you can adjust the headlamps manually. There is a dial behind the headlamps in the engine bay.
    If you do have auto-levelling headlamps (that wasn't available in the US or Canada), I believe you're looking for a load sensor.
