Headlight adapter hardness
Discussion in 'Gen 3 Prius Technical Discussion' started by Mclarengtrf1, Aug 16, 2025 at 1:23 PM.
  1. Mclarengtrf1
    Mclarengtrf1 Junior Member
    Touring + Tech
    I bought aftermarket headlights But the plugs will not fit is there a harness adopter available, I could not find any online
    SM-G960W ?
  2. PriusCamper
    PriusCamper Senior Member
    12,187
    4,950
    Pacific Northwest, USA
    You need to buy ones that are compatible with your vehicle... Adapters are very rare and re-wiring the plugs is only done when its the only option for the vehicle, which use to be the case back when this car first came out, but now there's plenty of options.
  3. xliderider
    xliderider Senior Member
    8,097
    3,244
    Honolulu, HI
    Well, it would help if you say what adapter you need, like H11 to H4, etc.
    Brian1954 likes this.
  4. Tombukt2
    Tombukt2 Senior Member
    12,448
    2,206
    Durham NC
    What's this hid ? I see adjust motors in pic I think gen3 hid? Usually it's h8 and h 11. And the bulb ends look like car grey plug doh. Tell me you're car and build type . I'll give ya a plug n play number that are running in my folks Gen 3.
  5. PriusCamper
    12,187
    4,950
    I definitely would do that if I knew... But the answer is as simple as typing into your preferred internet search engine "priuschat Gen3 LED headlight upgrade" and start reading.
  6. xliderider
    8,097
    3,244
    Honolulu, HI
    My response was directed to the OP, which is why I directly quoted their post.
    Grit and bisco like this.
  7. ASRDogman
    ASRDogman Senior Member
    7,314
    3,828
    I was thinking of getting replacement assembly's, but I can't find any that are the correct ones.
    They use different bulbs. So an adapter is needed. But since I cannot get a good answer for the
    type of adapter these places are selling, I'm not going to get them.
  8. xliderider
    8,097
    3,244
    Honolulu, HI
    Perhaps the OP can provide a link to the product they purchased?
  9. Grit
    Grit Senior Member
    6,500
    4,207
    Wilkes Land
    The fun on here is us throwing random guesses to see who right long after the OP comes back weeks to let us know.
  10. Grit
    Grit Senior Member
    6,500
    4,207
    Wilkes Land
    Ai search engine results, no time
    To browser
    Random posts
