headlight adjustment - Horizontal adjust - Can this be done? Please help
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jim Fussell, Dec 23, 2014.
  1. Jim Fussell
    Jim Fussell Junior Member
    Eufaula, AL
    After replacing low beam bulbs on 2010 prius, the low beams point 15 degrees left of center and 5 degrees down. I found the vertical adjustment but no luck with horizontal adjustment. HELP!!!!
  2. RavenTBK
    RavenTBK Junior Member
    Apalachicola National Forest, FL
    You might want to verify your replacement bulbs are properly seated in the housing. My P3, nor my wife's HiHy have a horizontal adjustment on the headlamps...only vertical. Horizontal out of whack is either a busted housing, or an improperly seated lamp.
    edit: Properly seated in the housing meaning all three tabs made it into their respective slots before the bulb was turned and locked into place.
  3. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    What he said... ^^^
