Headlight and Signal/Marker Light off and back on one side
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by revgaryng, Aug 21, 2014.
  1. revgaryng
    revgaryng New Member
    Henrico, VA
    Recently completed a six-hour drive and noticed right headlight--high and low beams--and right amber marker/signal light were off at night. Left or driver's side lights worked perfectly. Tried switching on and off and re-starting car with no different results. Parked car at home with intention of trying repair, next day. Next day, they were working fine! Any suggestions for checking or repairing welcome. Fortunately, we were close to home when this happened and it has not happened, since. What happened to make these lights go out on one side and, one day later, come back? Would like to prevent from happening again.
  2. Patrick Wong
    18,200
    6,479
    Check the wiring to the right headlight. It is likely that the wire that bolts to body ground is loose.
