headlight bulb for 2015 PiP?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by wiggleman, Mar 3, 2022.
  1. wiggleman
    wiggleman Junior Member
    86
    Arlington VA
    2015 Prius Plug-in
    My passenger-side lightbulb burned out. The replacement from Autozone should be an H11.
    But it doesn't fit. The pins are spaced wider apart, among other things.
    So what is the proper bulb to replace it?
  2. prius16
    prius16 Active Member
    462
    243
    New England
    2022 Prius Prime
    Is it the high beam? The high beam takes a PHILIPS 9005PR. That has a wider pin spacing than the H11 bulbs.
    #2 prius16, Mar 3, 2022
  3. wiggleman
    86
    Arlington VA
    2015 Prius Plug-in
    Hmmm, now I’ll have to double-check. Thanks for the tip!
  4. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    The passenger side headlight bulb is way over in the small confines of the corner, you probably removed the high beam bulb, which is a 9005. Yes, the 9005 pins are spaced wider apart than the H11 bulb.
  5. wiggleman
    86
    Arlington VA
    2015 Prius Plug-in
    A big handshake to all! I had indeed mixed up the high beams with the headlight bulbs. It’s now fixed. Thank you!
