Headlight bulbs out on right and left
Discussion in 'Gen 3 Prius Main Forum' started by H.S., Feb 11, 2023.
Tags:
  1. H.S.
    H.S. Member
    116
    26
    Venice, ca
    I discovered last night that two bulbs on the right and left of the front of the car are out . Is it typical for 2015 light bulb to be out or can be a wiring matter ? Or possible diagnosis!? No sure If it’s a bulb replacement or entire headlight..
    Looking for recs for shops in LA area for repair
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Probably just burned out bulbs. Passenger side marker bulb, and driver's side headlight bulb.
  3. H.S.
    H.S. Member
    116
    26
    Venice, ca
    Thanks. Is that common after 7 years or so? Any insight on fair cost for repair ?
  4. ChapmanF
    18,770
    A basic H11 headlight bulb might run you about twelve dollars, and a 5 watt W5W or 168 bulb for the parking light might be around a buck (or, say, $8.70 for a ten pack), and you can change them both yourself in seconds following the instructions in your owners' manual.
