HEADLIGHT BULBS
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by mahout, Sep 13, 2013.
  1. mahout
    mahout Active Member
    655
    116
    NC
    The headlight bulbs are
    low beams (outer) 9005 HB3, make sure its 2 oin, not 3
    High beams (inner) H11 HB2, make sure its 2 pin, not 3.
    I appreciate all the advice about checking owner's manual or 'specs' but I could not foind the ID of headlight bulbs. There are alternate bulbs with greater light distribution and extension but we have a selection and will let you know which are better.
    We haven't had time to find out if the adjustment on the headlights is horizontal or vertica but as of now I believe turning a phillips clockwise raises the aim of the headlights.
    The headlight bulbs are low beams (outer) 9005 HB3, make sure its 2 pin, not 3 High beams (inner) H11 HB2, make sure its 2 pin, not 3. I appreciate all the advice about checking owner's manual or 'specs' but I could not find the ID of headlight bulbs. There are alternate bulbs with greater light distribution and extension but we have a selection and will let you know which are better. We haven't had time to find out if the adjustment on the headlights is horizontal or vertica but as of now I believe turning a phillips clockwise raises the aim of the headlights.
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    You have that reversed. The low beams are H11 55w bulbs and the high beams are 9005 65w bulbs.
  3. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    low beams are h11
    highbeams are 9005
  4. mahout
    655
    116
    NC
    I may have but I could swear the outboard bulbs are 9005 and inboard H11; thats what happens tho when you get old. just wait, you'll see. Low beams are outboard, right ?
    In either case 100 watt bulbs are spectacularly better; now lets see with the 80watt bulbs and I'll verify those bulb positions.
  5. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Using higher wattage bulbs risks overheating and melting the OEM wires and connectors due to the higher current running through them.
    SCH-I535
