Headlight Cleaner or Protectant for a new Prius Plug-In
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by thx123, Jan 30, 2014.
  1. thx123
    thx123 Junior Member
    CA, USA
    2014 Prius Plug-in
    Just puchased 2014 Plug-In Prius. I love it!
    I see a lot of products and articles for "restoring" hazy and yellow headlight, but I do not see any good product recommendation for properly cleaning and protecting the headlight like you should wax the car. So you don't have to use the restoration kit later.
    Can I use regular car wax(I use Zymol) or is there a special cleaner / protectant that you use recommend?
    Thank you.
  2. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    I looked into this a while back and found some info on a car detailing forum.. but the members there were testing two products.. one was called Opti-Coat. Its about $60 for a syringe-ful (it needs to be air tight). Its actually a coating for car paint (that lasts a long long time). The other was, and don't laugh, Minwax.
    Headlight sealant: spar urethane vs. opti coat 2.0 - Auto Geek Online Auto Detailing Forum
    It seems as the thread progressed, people were trying other products too. And it seems the maker of Opti-Coat now makes a product called Opti-Lens specifically for headlight plastics.
    I havent done it, but I may do the Opti-Coat since I have a bit left. But since I've owned my car, I've just used Plexus after every wash to keep some UV protectant on it. I think most plastic polishes you buy in the store (from Mothers or Meguiars) all have anti-UV properties. There's always Aerospace 303 too..
  3. thx123
    CA, USA
    2014 Prius Plug-in
    Thank you so much for the info. I'll look into both Opti-lense and Plexus product.
  4. alekska
    alekska Active Member
    435
    138
    Atl
    Clear coat on the car paint and the coating on the lens are very similar. Car wax has a UV-protecting properties, so I always wax my headlights, and they are in pretty good condition. If they get dirty between waxing, I use Lemon Pledge (yellow can) to clean. I have used it on many cars on all kinds of surfaces and never had any problems.
    - Alex
  5. donbrownplug
    donbrownplug New Member
    2014 Prius Plug-in
    WAX headlights !
    The restore stuff is the similar to toothpaste ... fine grit to polish ... just wax it.
  6. xliderider
    xliderider Senior Member
    8,125
    3,265
    Honolulu, HI
    Whatever you use, look for something with UV protection or inhibitor.
    Wax might actually cause discoloration due to buildup.
    SCH-I535
  7. The Critic
    The Critic Resident Critic
    3,193
    2,330
    CA
    I've found that installing PPF over the headlight assemblies to be the only way to keep them clear.
    Do not apply Opti-Lens under the film before installation. There may be long term adhesion problems if the coating is not fully cured before the film is applied.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,832
    Clearwater, Florida
    Have used Meguires Mirror Glaze Clear Plastic Cleaner for 7 years on my car's headlights and they still look perfect. Think I got it at Walmart.
  9. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    That yellowing and cloudiness you see on some older cars' headlights is due to the clearcoat on the lenses failing, and then UV exposure causing the plastic to yellow. Most mfgrs seem to have gotten their act together wrt headlight lenses, as this problem seems much less common on cars built in the last say, eight years or so. The headlight lenses on my 2005 Prius are still crystal clear.
    Restoration for me consists of wet sanding, followed by polishing with progressively finer polishes until all sanding and polishing marks are gone. At this point, as long as the lens hasn't yellowed, the lens is clear, but with the clearcoat gone, the clouding and yellowing will soon reappear on the unprotected lens. At this point you could take your headlight enclosures to a body shop and have them shoot some clear on them, or for a DIY approach, applying a UV-inhibiting coating on them, like Optimum Opti-Lens (I have no experience with the headlight coatings included with the restoration products sold in auto parts stores, or using spray-on clears available in "rattle cans" on headlights).
    All I've ever put on my headlights is a little Opti-Seal paint sealant. I have not used Opti-Lens, although I would if I had to go through a complete headlight restoration. My priority for protective coatings is first the paint, then wheels, then glass, and last headlight lenses.
    alekska likes this.
