Headlight cleaners, any luck with specific treatments?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Acidbass32, May 6, 2015.
  1. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    About a year ago I go in a fender bender and the body shop replaced one headlight and just cleaned the other. Needless to say the cleaned headlight is cloudy again while the new headlight is clear as day. This really bugs me ( I'm a little OCD) and it just looks bad. I've tried the home remedies from toothpaste to rubbing alcohol, but its just not working. Now I do plan to paint the inner housing of the headlights black at some point in the near future, but I just wanted to see if there were recommendations of products anyone has had luck with.
    51,155
    have you tried that billy mays one?
  3. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    I have not. Is it any good?
    51,155
    i've only seen it on tv, but it seemed to work well. wipe on, wipe off. looked a little too easy though, tv infomercial and all.
  5. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    Yeah I'm always wary about that kind of stuff. My friend gave me a shamwow and that is exactly what it was, a sham.
  6. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    On the basis of this statement alone, I would suggest simply replacing the other headlight.
    If it was cleaned at the bodyshop, and was clear, but now has become cloudy again, my fear would be even if you clean it again, with something that works the affect will only be temporary. But...you don't have much to lose in experimentation.
    There are NUMEROUS over the counter headlight cleaners. All profess to work. Depending on HOW OCD you are? I don't think you have much to lose trying some of them.
    In my experience Meguiars makes good products, and they do make a headlight restorer.
    I'd try it. See if you can be happy with the results and if not? Then move to replacement.
  7. Acidbass32
    Acidbass32 Member
    217
    53
    Galveston, TX
    Yeah, I know I will have to clean them every couple months or so (probably more, being that I live on an island). So temporary is not an issue really, I am just tired of my car looking half assed cleaned. When I retrofit the headlight I will most likely give it a deep clean and clear bra the headlights so it prolongs the clarity.
  8. PLSPUSH
    PLSPUSH Active Member
    359
    132
    Tulsa, Okla.
    Walmart does a good job for around $40, they spent several hours on an old dodge van I had 3 years ago, my dad has the van now and they still look new
  9. beachbaby902
    beachbaby902 Junior Member
    Harrisburg, PA
    I used a headlight cleaner made by turtle wax i believe. The bottle had a green turtle on it. Used it on my old 97' Saturn. Worked great and stayed clear for a few years before i sold the car. I used the stuff on a buffer to clean the headlights.
    Anything you use, use a powered buffer. Should have better results. But honestly, i'd buy a new one.
  10. Robert Holt
    Robert Holt Senior Member
    1,313
    888
    Do you mean dirt/condensation on the inside of the clear plastic in front or cloudiness on the external surface?
    I have used the Sylvania 2-step kit to clean external oxidation off the plastic lenses on my 2003 Tundra and 2002 Saturn. The final result was clearly better than the original 10-year-oxidation cloudiness but also clearly worse than a brand-new headlight housing with new lens, which I got courtesy of a bus side swiping the Saturn.
    If you mean interior dirt/condensation , I would try to re-clean and seal all the seams on the cloudy unit, possibly inserting desiccant into a cool spot inside the housing.
    Had the same thing on Saturn and was also frustrated by the difference in the lenses.
  11. priusrecon
    priusrecon Member
    130
    43
    Upstate NY
    When I got my '04, the headlights were so clouded you couldn't see jack inside of them, and you couldn't use them at night. It was like somebody had spray painted them with frosty yellowish white paint they were so bad.
    I got a kit from Meguires, cost me $29 and had a sanding block, 2 grits of sandpaper, a polishing wheel for a power drill, and a polishing compound.
    Followed the instructions. Took me 90 minutes, and now those headlights literally look brand new from the factory. They now look so good they are like jewelry on the front of the car
    Riff Raff, Acidbass32 and Robert Holt like this.
  12. gardson
    gardson Junior Member
    SC
    If the headlights are not too yellowish or hazy, using toothpaste works good.
