headlight condensation
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by marpet30, Oct 24, 2013.
  1. marpet30
    marpet30 Junior Member
    We just bought a new Prius II (2013) 6 days ago and had rain. We noticed condensation in both the front headlight and back tail light. This is under the plastic covering. This doesn't seem right. We searched and found a class action suit for the previous generation prius. Is this a problem for anyone? What have you done? Do we need to be concerned about this? Help, please? (my first post as a newbie).
  2. El Dobro
    El Dobro A Member
    6,978
    3,213
    Bring the car back to the dealer for warranty coverage.
  3. marpet30
    thank you, we will do that
  4. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    Also try posting in the Gen II forum.
    Oh, NVM, you said Gen II but actually have a Gen III sounds like.
  5. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    I had this problem on a another new car, and the dealer replaced both lights under warranty.
    Though you may have to distinguish between a sealed light which is defective vs. just some moisture got in to the open light socket hole, which can possibly be aired out (some Gen2 posts on this issue).
  6. El Dobro
    El Dobro A Member
    6,978
    3,213
    The OP has a 2013 Prius Two.
  7. Grren4ever
    Grren4ever Active Member
    347
    166
    If you read your manual carefully, it states that condensation in the lens is temporarily. The first few days I had my new prius, I noticed condensation. After that, I have never seen it come back.
    Of course if you have water droplets coating the entire inside and the lens holds enough water that it could be an aquarium, I'd be concerned! good luck.
  8. marpet30
    thank you so much!
  9. Trung Quang
    Trung Quang Junior Member
    I noticed some in mine as well after a car wash. I'll let it sit for another day and if it stays I'm gonna bring it in
  10. Swordfish380
    Swordfish380 New Member
    Stnford
    This is the fix for headlight condensation for Prius 2010 or higher models. Try to find a dirty sand color spot where the V section of the headlight is on the top. This v section is where the side fender cuts into the headlight.
    At home Depot fine a clear silicone for $3 cut the tip of the tube and squeeze it through the small opening between headlight and fender. This fixed my condensation issue.
    Right way is to disassemble the headlight and apply silicone or adhesive. 2017-07-04_14.49.42.jpg
