Headlight issues
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LisandroJ125, Feb 13, 2025.
  1. LisandroJ125
    LisandroJ125 New Member
    Greetings everyone. I hope to get assistance or suggestions regarding a headlight issue in certain Gen 3 Prius models. My passenger-side headlight recently burned out on my 2010 Prius (purchased about a year ago). The previous owner installed LEDs, a common fix for frequently burning out bulbs. I found what I believe were the same bulbs on Amazon, but they burned out in less than a day. Now I'm thinking the issue lies somewhere in the harness. Should I just replace the H11 connector, which appears okay, showing no signs of burns or looseness, or should I take the time to remove the front bumper one day and check the entire harness? If so, how do I go about it without opening all of the harness? Could it be a fuse?
    Any suggestions or feedback will be appreciated.
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    765
    301
    Maine
    #2 ForestBeekeeper, Feb 13, 2025
  3. Grit
    Grit Senior Member
    6,411
    4,181
    Wilkes Land
    Check if the vehicle had the headlight recall performed. If not, get it done. The voltage will be adjusted for the recall so it doesn’t put out voltage higher than most headlamp operating voltage.
    MAX2 likes this.
  4. Grit
    Grit Senior Member
    6,411
    4,181
    Wilkes Land
    Extra curricular reading not wanted
  5. rjparker
    rjparker Tu Humilde Sirviente
    9,485
    5,808
    Texas Hill Country
    The Toyota halogen tsb for 2010-11 models is no longer free. It simply spliced in extra wire length to reduce battery voltage, dim the halogen bulb slightly but extend their life.
    I would get some Lasfit H11 LEDs low beams and call it a day. They can take the voltage and have a good beam pattern to avoid blinding traffic.
    H11 H8 H9 LED Bulb|LA Plus Series|Lasfit Auto Lighting – Lasfit®
    Otherwise you need the Basic Phillips or Sylvania halogen bulbs to get long life. The bright halogens say right on the box they last 1/8 of the time as the factory Basic halogens.
  6. xliderider
    xliderider Senior Member
    8,032
    3,211
    Honolulu, HI
    I installed AC HID ballasts and bulbs over 10 years ago, our 2011 never had the harness recall work done.
    HID ballasts can take a very wide range of voltage, so the chances of higher voltage to the ballast through the OEM H11 connector causing damage is very low.
    Good quality HID bulbs last over 5 years.
    SM-G781V ?
    #6 xliderider, Feb 14, 2025
