Headlight Leveler Socket
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by The Phoenix, Jan 18, 2018.
  1. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    I am trying to replace the socket that the headlight leveler sensor plugs into and I would like to know if anyone can verify the information I have so far. A Toyota dealership said the socket part # is
    90980-11016
    And it seems to be correct,
    The three wires that go in it sounds like they are all the same kind of wire and gave me this part # and said I would need 3,
    82998-12440
    If anyone has knowledge or experience with this I would appreciate any feedback, thank you
  2. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    Here are some pictures I got from the vehicle owner, and a picture of the part #
    20180118_141228.jpeg 20180118_141239.jpeg 20180118_141246.jpeg Screenshot_20180118-134426.png
  3. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    Another update on my original post 90980-11016 does not seem to be anything close to what I need....hopefully someone knows the correct part I need
  4. ChapmanF
    15,887
    Welcome! I wrote this earlier post (and the one it links to) as a guide to how you find the exact part numbers you're looking for in your wiring diagram at techinfo.toyota.com.
    -Chap
  5. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    Very cool I will have to save that for future reference Chap. I had a long conversation with an extremely helpful Toyota parts guy, who then called me back after talking to a master technican and got me the part # I was looking for
    90980-11860
    Thank you for the information I will definitely use it in the future
  6. jzchen
    jzchen Newbie!
    3,298
    1,010
    Arcadia, CA
    I tried to look on parts.toyota.com, but couldn't find it. Glad you got the part number!
  7. Mendel Leisk
    38,891
    When there's not a readily available part number, it's because it's usually sold as part of a larger assembly, ie: a whole new wiring harness? Which would be a bit of a sand-pounder, I know.
    Those pictures, especially the first, illustrate the incredibly deleterious effects of salty winter conditions, btw.
  8. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    You won’t find a part number for connector as that was put on the car as an entire wiring harness. But Toyota does sell repair parts for wiring harness.
  9. ChapmanF
    15,887
    As far as I can see, the OP did find a part number for the connector (see post #5), and, in general, you can find part numbers for nearly all the connectors used in the wiring harnesses, right in the wiring diagram as explained in post #4.
    -Chap
