Headlight low beam bulb burnout
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dblomgren, Feb 5, 2014.
  1. dblomgren
    dblomgren Junior Member
    Coeur d'Alene ID
    I have had 5 bulbs burnout in 2 months. I'm not touching the bulb and I am using grease. I've tried the higher end sylvania bulbs and they still don't last. Any ideas as to what might be causing this?
  2. JC91006
    16,827
    8,600
    That seems unusual for 5 bulbs to burn. There can't possibly be 5 different defectives bulbs of different brands....I'm curious why do you use grease?
  3. dblomgren
    Coeur d'Alene ID
    It's suppose to reduce heat
  4. JC91006
    16,827
    8,600
    are you using the correct bulb?
  5. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    Where did you hear about using grease. I have no heard that before.
  6. JC91006
    16,827
    8,600
    My friends use a "Hella" brand bulb from Amazon. It's about $8.00 each. Made in Poland but seems to hold up quite well. I would try that and not use the grease.
    HELLA H83160211 HB2 9003 Series 12V 60/55W Bulb
    OOPs. That's a GenII bulb.
    I'm still suspecting there maybe another issue as you've burned 5 bulbs already. I can't believe quality control is that poor.
  7. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,731
    1,768
    Bay Area
    The Bulb grease is die electric grease, you apply it to the connection tab of the bulb to prevent heat from the electrical. It's common to prevent corrosion on the terminal as well.
    As for the bulb burning up, I would check the bulb connection if the current is within spec or not. A short somewhere in the line can cause high current to run through the wires and cause a short on the filament and can cause premature wear on the bulb. I hope that helps?
  8. pmike
    pmike Member
    237
    81
    Central Florida
    SilverStars are garbage and burn out quickly. You are also in the 3rd gen sub forum and do you have a 2nd gen or 3rd gen. If you have a 3rd gen do the H11 to H9 mod.
  9. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    OP, do you leave your headlight switch in the ON position all the time? Doing so exposes the bulbs to voltage and current fluctuations at startup and will drastically shorten bulb life.
    Waiting even a few seconds after startup before turning them on will help.
    SCH-I535
  10. gary sciascia
    gary sciascia New Member
    grease prevents corrosion from developing at the contact point where the bulb plugs into the wiring harness. High resistance electrical connection
    can draw a small arc when powers applied to the bulb and over time could pop the bulb like an crusty old wall switch in your house can.
  11. gary sciascia
    I started turning the light switch off everytime I turned off the car as I used to leave it on and have gone through 7 of the Sylvania ultra h11-su2 bulbs
    in 10 months. Didn't make a difference. I was hoping it would as I understand a voltage spike as the system voltage increases to normal operating voltage everytime you start the car could be a problem. Not in my car's case.
  12. xliderider
    8,140
    3,277
    Honolulu, HI
    What year is your car? There was a TSB for the gen3 2010/2011 MY Prius that had a headlight harness replaced.
    We have had no problems with our 2011, but I am using H9 65w halogen bulbs instead of H11 bulbs for my lowbeams (link in my signature below).
  13. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    reduce heat where?? and of what ??
