Headlight (low beam) ring and seal replacement help
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Khalil19, Nov 18, 2023.
  1. Khalil19
    Khalil19 Junior Member
    Quincy
    Does anyone know what is the part number for this rubber seal,
    its H11 low beam housing for 2013 prius C
    Thanks
  2. Tombukt2
    Tombukt2 Senior Member
    9,131
    1,585
    Durham NC
    I do not but I'm sure there's a parts breakdown on Prius chat look it up something something.com or the Toyota website I might be on in a little while I'll try to look it up It looks like a headlight mounting ring that's your bulb or bulb assembly or bulb holder inserts and twists into or something along those lines by the look of it I don't know how it got this destroyed maybe just heat and you'll go back with LEDs and this will eliminate that forever.
    Khalil19 likes this.
  3. Tombukt2
    9,131
    1,585
    Durham NC
  4. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    I believe you have to change the entire headlight assembly.
    Someone installed the bulb incorrectly at an angle and the heat from the bulb melted the plastic. Unfortunately, that part of the housing isn't available by itself.
    You can usually find used parts at pick a part yards or ebay, etc.
    Khalil19 and Brian1954 like this.
  5. Tombukt2
    9,131
    1,585
    Durham NC
    If that's the case the aftermarket's got you covered three ways to Sunday
