Headlight Overhang at Shutdown?
Discussion in 'Gen 2 Prius Main Forum' started by jimolson, Nov 10, 2023.
  1. jimolson
    jimolson Member
    159
    58
    Indianapolis, USA
    Gen II Prius has an annoying feature that its headlights remain on beginning when the vehicle shutoff button is pressed and ending when the driver side door is opened.
    If you pull the vehicle over during the day to implement a long cell phone call, the absence of a prompt "door open" means that the headlights could remain on while you talk and you don't realize it.
    It's not unusual for the 12VDC battery to run down sufficiently during a long cell phone call, enough to prevent the motor from restarting at the call's conclusion.
    Is there a chicken dance-like method for defeating this annoying headlight overhang feature, or at least shorten the period that the lights remain on without the door being opened?
    52,353
    there might be a setting in tech stream, idk.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Yes there is. Place hand on light switch. Turn the headlights off. Press the power button. Enjoy your phone call. Open the door.
  4. PriusCamper
    PriusCamper Senior Member
    13,020
    5,291
    Pacific Northwest, USA
    Thanks, there was a time I had a regular parking spot that was a tight fit and required me to exit from the passenger side door. Drained the battery down a couple times because of that.
  5. bisco
    52,353
    i just crawl out through the window
  6. rjparker
    rjparker Tu Humilde Sirviente
    10,469
    6,564
    Texas Hill Country
    The vehicle settings.
  7. PriusCamper
    13,020
    5,291
    Yeah... I heard you welded the doors shut too. Way safer when you jump the car regularly...
  8. Mendel Leisk
    41,865
    From page 487 of North American edition of Owner's Manual. It's not clear if this is easily customizable by owners, or requires Techstream.
    No clarification on page 152:
    Got a hunch it does require dealership (or someone with Techstream), and custom settings are lost if battery is disconnected. I think that's the case with gen 3 anyways.
  9. dolj
    dolj Senior Member
    8,550
    4,343
    Wellington, New Zealand
    No, not as far as I'm aware. Also as far as I'm aware, the lights stay on indefinitely unless and until the door is opened.
    Another option is to not press the vehicle shutoff button.
