Headlight problems
Discussion in 'Gen 3 Prius Main Forum' started by Bob Foreman, Dec 11, 2017.
  1. Bob Foreman
    Bob Foreman New Member
    Grayson, GA
    Prius 2, is 2014 model. Headlight problems started with about 60,000 miles on car at same time radio, Bluetooth, and rear back up video screen quit working (turns on and off continuously). Seems to be major electrical problem. Dealer claims the headlight bulbs were burned out. Dealer replaced headlight bulbs ($300), but new bulbs are very dim. I am unable to see the pavement or objects in front on a dark country road. Even city driving is unsafe. Prior bulbs were much brighter. Did they install wrong bulbs? I took the car back to dealer, but they claim they can find nothing wrong with headlights. It is not safe to drive car at night. Dealer has ordered a new radio/bluetooth and backup camera screen, but it will cost almost $900. It will not solve headlight problem. I cannot drive car at night. My next step is to try another dealer. Suggestions from anyone will be appreciated.
    49,490
    welcome!
    you need an expert electrical diagnostician. maybe look around at aftermarket shops and etc.
    is it possible that rodents are chewing on your car's wiring?
  3. Snow
    Snow Member
    91
    63
    Pewaukee, WI
    Could you post a picture of the headlight output on a dark road? First thing I can think of is that the headlight could maybe be aimed improperly? Next, if you need a bulb replacement I'd look to get it done elsewhere, the bulbs aren't very difficult to change. Especially not $300 worth of difficulty.
  4. ATHiker
    ATHiker Senior Member
    642
    560
    Massachusetts
    Four Touring
    Just got a letter from Toyota about a “Warranty Enhancement Program” for our 2010. This was put in place because customers have indicated that halogen low beam headlamp bulb lifetime is shorter than expected.
    Says they will replace bulbs and wiring harness until Oct. 2019 regardless of mileage. This may be for just 2010s though.
  5. AzWxGuy
    AzWxGuy Weather Guy
    982
    496
    Tucson, AZ
    2021 Prius
    The warranty enhancement program applies to 2011 also, since I received said document in the mail yesterday. And I just, at the beginning of last month, noticed that my drivers-side low beam was out. So I hunted down the appropriate Philips bulbs and replaced them myself. Went with the Philips H11 X-treme Vision, which made the usual claim of some sort of improvement over what you have now. In this case, a whopping 100% improvement in beam performance. And their not those goofy blue tint bulbs you see all over the place. Looking closely at the bulb, I did notice a narrow blue tint strip around the top of the bulb just below the blackout cap. The packaging says 3400K light color and 55 watt. I would say they definitely light up the road much better, but the bulbs that came out of there had over 150K and 6 years of filament dust brown-out. I wonder about the wiring harness replacement, some sort of current-limiting arrangement to extend bulb life. That might also reduce illumination. I don't know, I think 150K for a headlight bulb is pretty good. So I don't think I will participate. These replacements were only $65, which is well within the range or normal maintenance costs.
  6. drysider
    drysider Active Member
    823
    332
    Liberty Lake WA
    Have you checked the 12v battery?
  7. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    I'd be amazed if you got 150k out of the oem bulbs.
    Expect to get about 6 to 18 months out of the new bulbs. All of the newer xtreme/plus/platinum, etc bulbs are designed to burn hotter and brighter. Combine that with the 14+ volts the Prius supplies and you get shorter bulb life.
  8. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    The replacement headlight wiring harness simply acts as a resistor to drop the voltage, as has already been explained in detail in Priuschat.
  9. hayden55
    hayden55 Member
    115
    48
    All cars have a running voltage of high to mid-14v's. They are only 12.5v when the alternator isn't running.
  10. ChapmanF
    15,615
    The voltage that matters to the headlight bulbs is the voltage at the headlight bulbs. The EEs designing the wiring harnesses have tricks up their sleeves to get that down closer to the nominal 12.8 the bulbs are designed for. Except when they don't....
    -Chap
  11. Yippeekyaa
    Yippeekyaa Active Member
    137
    160
    North Carolina
    300$ for headlight bulbs? What a ripoff. You got hosed. Find a good hid retrofit shop near you and for less than what the stealership charged your car can have amazing night vision. I installed one myself for under 100$.
  12. Mike01886
    Mike01886 New Member
    MA, USA
    Just got a Warranty Enhancement Program announcement for 2010-2011 Prius.
    It is to replace the halogen bulbs and wire harness. Or if you have receipts you can get a refund of your expenses.
    Looks like a nice no cost deal for us owners. I replaced my headlights last year and now one is out again, so the timing is good for me.
    I called my dealer and there appears to be a national shortage of the new version of this harness. I called headquarters and the operators are unaware of a shortage. I quickly checked online and couldn't find any harnesses new version or old. Amazon has the old ones but they are out of stock.
  13. Bob Foreman
    Grayson, GA
    UPDATE on headlight problem: I took the Prius to another dealer (Milton Martin Toyota, Gainesville, GA) where the car was originally purchased. They were able to fix the headlight problem. They said the headlight bulbs had been installed incorrectly. When they were correctly installed, the headlights worked properly and lighted up the road in front of the car very well. The incorrect installation placed the bulbs in the wrong location. They could not provide the correct amount of light because the bulbs were positioned wrong in the mounting area. It was as had I told the Stone Mountain Toyota service people, the lights were aimed down on the pavement right in front of the car, but not straight ahead. I can drive the car at night again, after, 3 months. Now I just need to deal with the radio/back up screen problem.
    Rwm and bisco like this.
  14. xliderider
    7,869
    3,116
    Honolulu, HI
    You are lucky that the improperly mounted bulbs didn't melt the surrounding plastic in the headlight housing. That would have required in replacing the whole headlight assemblies.
  15. bisco
    49,490
    i had no idea you could mount headlight bulbs in more than one location. what would be the purpose of those other locations?
    Rwm likes this.
  16. bisco
    49,490
    what did the second dealer say about the radio?
  17. xliderider
    7,869
    3,116
    Honolulu, HI
    Improperly mounted in the correct locations. ;)
    It's easy to only engage one of the 3 tabs in the bulb base, resulting in an off-angle bulb, especially on the passenger side due to tight conditions behind the headlight housing.
  18. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    I did exactly this on the passenger side of my 2010. It was easy to see something was off when I stood in front of the car with the headlights on. The driver's side was "brighter" because it was installed correctly. Once I removed and replaced the passenger side I realized my mistake.
    xliderider likes this.
  19. xliderider
    7,869
    3,116
    Honolulu, HI
    Yes, always check with lights on after removing and replacing bulbs. It's very obvious when something isn't mounted properly.
  20. bisco
    49,490
    i can't believe a dealer couldn't figure that out.o_O
    Rwm likes this.
