Headlight socket burned!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ePRIU$, Jan 6, 2020.
  1. ePRIU$
    ePRIU$ Junior Member
    35
    The right side headlight socket is burned, please help me to identify the part, just the socket only if possible. An entire head lamp is expensive. I need to part number and instruction how to, thanks.
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    I'm pretty sure you will need to replace the entire headlight assembly with a new or used one. Maybe you can get lucky and find one at a salvage yard for much less than a new one.
    Raytheeagle likes this.
  3. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    You can jb weld a bulb back on but buy LED bulb which is cooler
  4. JC91006
    16,827
    8,600
    The bulb wasn't installed right and it melted the plastic around the housing. You can do a mickey mouse job on it by gluing it, but to fix it properly, you would need to replace it. Buy a used one if you can
