Headlights Auto Off Question
Discussion in 'Prius v Main Forum' started by rjparker, Oct 14, 2018.
  1. rjparker
    rjparker Tu Humilde Sirviente
    9,590
    5,889
    Texas Hill Country
    Yesterday I was waiting in the car for about an hour. I parked, rolled the windows down and powered off the car. My v3 has auto on off for the headlights so I never touch the control. I know that they go off 30 seconds after exiting the car, but I never left the car. Power was off the whole time, but I ended up with a discharged 12v and then no start. Question is - will the auto off headlights remain on for an hour in this scenario or is there a timeout?
  2. fuzzy1
    10,335
    At least on my Liftback, the countdown timer (which I have customized to 0 seconds) starts with either opening or closing the driver's door. If you never open it, the timer never starts.
    Likewise, if you exit instead through the passenger door, never opening the driver door, the auto-off won't work.
    Raytheeagle and JimboPalmer like this.
  3. scona
    scona Active Member
    225
    206
    Courtenay, BC, Canada
    2013 Prius v wagon
    The ferry system here in BC has routes that run from an hour and a half to 2 hours. People never open the driver's door to exit, the vehicle lights stay on but are not visible in the daytime. They tow the offending Prius off and will not boost it because they fear something drastic will happen. If you remain in the car when it is powered down open the driver's door and then the lights switch off. Then close it and you are all set.
    Mendel Leisk, fuzzy1 and Raytheeagle like this.
  4. rjparker
    9,590
    5,889
    Texas Hill Country
    I think this was one of those questions I knew the answer but... It was still light outside when I parked. It seems the accessory mode will beep when the 12v is low but not the Power Off mode if you stay in the car. I guess I need to buy one of those lithium jump starts and carry it around.
    I was reading specs on the jump starts last night thinking something that stayed charged via the switched 12v in the back might be good. But it seems most need a plug in ac charger except for this line of "NOCO Genius Boost" which have units from $79 up to $2500! The "1000 amp" $99 version seems well received as Amazon's current #1 seller.
    Any experience with a NOCO on a Prius?
  5. mikefocke
    3,899
    1,755
    Sanford, NC
    Why not just get in the habit of turning the light on and off.
    When on the ferry, you sit for up to two hours and don't get out to stretch your legs, go to the bathroom, get a drink of water, talk to people?
  6. rjparker
    9,590
    5,889
    Texas Hill Country
    First time in seven years this has happened. My USAA insurance provided a jump start free in about 15 minutes and the negative reinforcement will carry me a few years. As far as ferries go, they are scarce down here in Central Texas. I believe they have one at Aransas Pass on the coast but it's maybe 15 minutes. These days the Prius is a commuter car and is unlikely to ever see that ferry.
  7. fuzzy1
    10,335
    On my pre-DRL cars that had auto-off, I intentionally made it a habit to not turn the lights off when shutting down. This helps ensure that the lights are on the next time the vehicle is driven.
    The enhanced traffic safety greatly outweighs the rare risk of OP's situation.
  8. rjparker
    9,590
    5,889
    Texas Hill Country
    This is exactly my thinking. I also see people driving without lights at night, probably because their digital dash and street lights make them think their lights are on. Still looking for anyone with experience on the lithium jump starters on a Prius.
    fuzzy1 likes this.
  9. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
  10. Mendel Leisk
    40,575
    I never use the auto headlights function, for a variety of reasons. Maybe foremost: it's clinically impossible for me to walk away from a car with the headlights ablaze. Also, I sometimes like to run full headlights in daylight, overcast days in particular, I think auto headlights just turns them on at dusk, off at dawn?
    I have a Clore Jump-N-Carry JNC660 stowed in the tray under the hatch floor, fits nicely. Never needed it for our car, have jump started a few others, once in a blue moon.
    We've been on our share of BC ferries, but of late have been finding it too expensive, mostly staycation.
  11. rjparker
    9,590
    5,889
    Texas Hill Country
  12. fuzzy1
    10,335
    That would be an auto-on issue. I believe OP's car lacks that feature, but merely has auto-off. I.e. it doesn't turn headlights on in response to darkness, but simply turns them off when the car is shut down.
    Not impossible for me, but still not easy either. That is one of the reasons I turned the delay, set at the factory to 30 seconds, down to 0.
    #12 fuzzy1, Oct 14, 2018
  13. rjparker
    9,590
    5,889
    Texas Hill Country
    My v3's "auto" mode simply turns the headlights on with the car, regardless of light or dark outside. Since the car does not have Daylight Running Lights, I use this mode and just run the headlights anytime the car is powered up. The savings on insurance makes it worthwhile as well as the safety aspects. I also set the turn off time delay to zero, but as we know, that does not trigger unless the driver opens and closes his door.
  14. mikefocke
    3,899
    1,755
    Sanford, NC
    I installed a $$$ DRL kit from Toyota on mine so I am always visible from the front. And in the rear, unless it is rain, snow or dark, I prefer the contrast between my white car and the suddenly red taillights. Having had an accident partially because the truck in front of me was red and I didn't pick up the contrast due to the position of the sun. So on a pre DRL I agree. I'm constantly amazed at the number of cars with no light on just after dusk as it starts to get truly dark. Or the number of cars with only one taillight or headlight. A week doesn't go by without me pulling up beside someone and getting their attention to tell them. I get the strangest looks sometimes before they tumble to the fact that I'm asking them to roll their window down so I can talk to them.
  15. tvpierce
    tvpierce Senior Member
    951
    881
    Maine
    2013 Prius v wagon
    There's no need to keep to those lithium-ion battery jumper packs topped up like you would if they contained a lead-acid or NiCad battery -- in fact, it's not good for their battery.
    If you charge it up to full capacity, you could leave it sitting in your car for several years and it would still have enough power to start a conventional vehicle that uses an electic starter. When you consider the Prius just needs it to cycle on the electronics for a few seconds, it would probably have enough power to start a Prius after sitting for 5+ years.
    Having said that, it would probably be prudent to charge it once/year if you never used it. Take it out, and charge it overnight in your house, or leave it plugged in to the cigarette socket on a several hour trip... then leave it for another year. Doing so will extend the battery life.
  16. rjparker
    9,590
    5,889
    Texas Hill Country
    I am sure you are right. It also has a led display that provides charge level when enabled. Kind of waiting for someone's conventional car to need a jump to see if this thing really works as advertised. This is the one I bought. Bigger than the paperback book sized ones you see at Costco. noco.jpg
    Raytheeagle and tvpierce like this.
  17. Air_Boss
    Air_Boss Senior Member
    4,139
    1,154
    New Yawk
    Great Joules of Fire!
  18. tvpierce
    951
    881
    Maine
    2013 Prius v wagon
    That looks like a good one. Sure it's overkill for starting our cars but as you say, part of the reason for having a jumper like this -- or for carrying jumper cables in a conventional car -- is to be able to help others in need.
    Another use for these jumper packs is if you go off grid camping, or if you lose power during a storm, they work great for charging cell phones and other small electronics. You could charge your family's cell phones for weeks with the pack you got from Cosco.
    #18 tvpierce, Oct 24, 2018
    Raytheeagle likes this.
