Headlights feel dangerous
Discussion in 'Gen 5 Prius Main Forum' started by cool_prius, Mar 11, 2025.
Tags:
  1. cool_prius
    cool_prius Member
    106
    37
    United States
    2025 Prius
    Maybe this is a side effect of me owning a car with accurately positioned headlights for the first time, but the headlights feel dangerous as they are. Unless the road is completely level, they only light a car's length away and then it's pitch black after that. No improvement with high beams, as it only makes that same area brighter.
    I took it to a Toyota service center to have them checked, and the tech said they're fine and that they're at the level they should be. I believe it, but maybe they're designed with perfectly marked roads in mind. I just drove 60 miles through winding mountain roads with no reflectors and street lights at night and it was one scary drive.
  2. ETC(SS)
    7,164
    What was your prior car?
    You're posting this in the G5 forum, so one presumes you have a G5, which has ADEQUATE lights to be sure, although you may be driving a smaller car than you're used to and it's a lot closer to the ground.
    It's possible that you're either trying to 'outdrive your headlights,' or your vision isn't what you may think it is.
    I have over 200,000 miles in G3s.
    Same small car, but your (G5) lights should be a lot better!
    I've never felt that the lights in these cars were inadequate.
  3. Leadfoot J. McCoalroller
    8,092
    7,573
    Pennsylvania
    2018 Prius c
    A lot of modern headlights are so bright that they fool your eyes back into day mode, so you can only see things hit by your own lights.
    Older car headlights were dimmer and by consequence you'd sort of stay in night-vision mode, you'd just have an easier time seeing what your lights were aimed at.
    Winston Smith and Trollbait like this.
  4. Paul Gregory
    Paul Gregory Senior Member
    2,157
    566
    Alberta
    2024 Prius Prime
    XSE
    My Gen 3 had such bright headlights, that even on low beam, opposing traffic flashed their lights as though I was on hi beam.
    My Gen 5 seems about right in my opinion.
  5. Winston Smith
    Winston Smith Active Member
    359
    241
    OH
    2024 Prius
    LE AWD-e
    And those new lights aren't just bright, they also have a razor sharp cut-off.
    In the days of the sealed beam, we projected much less light, but the light was a soft center of yellow that got weaker farther out, so you has some weak spill that let your still present night vision see upward and to the sides more than you may today.
    Current lights project a nearly uniform field of blue/white light into a very well defined area. The consequence for oncoming traffic is that falling within that field looks as if you've left your high beams on; you see less well because your night vision is trashed by the same oncoming traffic. On roads without lighting, not seeing the ditches and trees lit up can be disconcerting, but you aren't driving toward those anyway.
    I'm not sure what the easy fix is. Headlights are so complex and expensive that replacement doesn't seem economic. Even if you had your lights altered, you'd still have to deal with everyone else's.
    #5 Winston Smith, Mar 11, 2025
  6. CooCooCaChoo
    CooCooCaChoo Senior Member
    957
    535
    Cow-lee-fornia
    2023 Prius
    Yeah, the headlights do feel like they are aimed too low so I adjusted them up a bit more. If you do the same, just don't adjust them too high such that you are blinding oncoming cars.
    daisy555 likes this.
  7. bisco
    51,966
    Wait until you have to replace one $$$$$
  8. SkiLodge
    SkiLodge New Member
    PNW
    2024 Prius
    Limited AWD-e
    On an unlit, fairly familiar road, I completely missed the driveway I was trying to turn into the first night I had my new gen 5.
    This was coming from a gen 2 where I think the lights were angled too high.
  9. mva
    mva Member
    137
    82
    B.C. Canada
    2024 Prius Prime
    SE
    I also adjusted mine up. Easy to do - I believe it’s an 8 mm socket. There’s a pretty good YouTube video on how to do it. I raised mine 6 notches - when you take a close look with a flashlight you’ll see what I mean. They’re better now.
  10. Cactus
    Cactus Junior Member
    28
    Mountville PA
    Yes night driving sucks. I am definitely going to adjust mine when I get a chance.
  11. Jotunn
    Jotunn New Member
    17
    High Point, NC
    2024 Prius Prime
    XSE Premium
    I adjusted mine up significantly and it is soooooo much better. Nobody has flashed me for several months now since I adjusted them so I assume anecdotally that they are still safe.
  12. Paul Gregory
    2,157
    566
    Alberta
    2024 Prius Prime
    XSE
    If your night vision is poor, you should definitely not drive at night.
    PrimeDan likes this.
  13. daisy555
    daisy555 Senior Member
    1,715
    710
    CT
    When I did a test drive at night I was a bit disappointed in the headlights. There seemed to be patches of darkness/shadows in front of me which I’m assuming are caused by the L shape headlight design maybe?
    #13 daisy555, Mar 14, 2025
  14. stuyguy
    stuyguy Active Member
    170
    134
    Lakewood, CO
    2024 Prius Prime
    XSE
    Had my dealer adjust them but they raised them too high; oncoming cars were flashing me. Lowered them some myself
  15. cool_prius
    cool_prius Member
    106
    37
    United States
    2025 Prius
    The dealer I bought it from said they couldn't adjust it for me since it's at the correct level. I guess it's a hit and miss thing.
  16. Gokhan
    Gokhan Senior Member
    6,232
    2,469
    Paramount CA
    According to IIHS, they have an “acceptable” rating by IIHS—same as my 2021 Prius Prime Limited. So, they are OK but not great.
    2024 Toyota Prius—IIHS
  17. Gokhan
    6,232
    2,469
    Paramount CA
    Corolla and Corolla Hatchback got a “good” headlight rating by IIHS. Corolla Hatchback has a far better taillight design than that of the Gen 5 Prius, too—similar to that of the Gen 4 Prius Prime. It is too bad that Corolla Hatchback does not come in an HEV version.
    2024 Toyota Corolla Hatchback—IIHS
    The redesigned Corolla is coming next year, and there will also be a PHEV version. It will debut the new revolutionary Toyota super-lean-burn 1.5-L engine, which is expected to result in an EPA fuel economy of 70+ mpg—far better than that of any previous and current Prius generations. Perhaps you should wait for another year for the resigned Corolla.
    2027 Toyota Corolla could launch next year with a plug-in hybrid option | Carscoops
    #17 Gokhan, Mar 15, 2025
  18. cool_prius
    cool_prius Member
    106
    37
    United States
    2025 Prius
    The Corolla Hatchback has a far better taillight design? Disagree. All I see is lobster and cheese.
  19. Trollbait
    12,543
    Driver side light will be aimed lower to reduce glare to oncoming traffic.
  20. Gokhan
    6,232
    2,469
    Paramount CA
    The L-shaped light is only an accent light. The headlight itself is a single circular LED lamp. My Gen 4 Prius Prime has quadruple square-shaped LED headlight lamps.
    CooCooCaChoo likes this.
