Headlights getting milky looking.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by triumph1, May 25, 2011.
  1. triumph1
    triumph1 Member
    275
    Seems like the clearcoat on both of my headlights is starting to get milky. Whatever is going on, it is happening from the outside. I buffed on them with scratch remover and put a coat of wax on them, (looks a little better now) but there is something going on. Any ideas, anyone else having this issue?
  2. Mendel Leisk
    38,879
    I think there's a caution in the owners manual about not waxing the headlights (at least in the 3rd gen book).
  3. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    I saw an ad recently for a product designed for headlights. I think it was Meguiar's, but I'm not sure. An internet search should turn up something.
  4. macmaster05
    macmaster05 Senor Member
    4,050
    729
    Such a dirty title. :p
  5. Paradox
    29,110
    8,590
    201
    2014 Prius v wagon
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    My wife thought the same thing about ours. After her cataract surgery they looked much better.
    Tom
  7. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    The Meguiars restoration kit will improve the appearance about 80% if they are very cloudy.
    Our vehicles always got this way when we lived in FL.
  8. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
  9. hpartsch
    hpartsch Member
    102
    pa
    hahahahaha
  10. mikewithaprius
    mikewithaprius New Member
    656
    103
    Rhode Island
    Hey triumph, just fyi, it's from the sunlight, you probably park it outside, right?
  11. Rest
    Rest Active Member
    1,210
    53
    CA
    This has happened to several of my vehicles I have owned. It's the UV coating that eventually starts to peel/flake. This happens more so to vehicles that are parked outside in the Sun, instead of inside a garage. But yes you can buff off the damaged UV coating as you have done, but now the plastic lens will ultimately be damaged by Sun exposure turning foggy and brittle.
  12. Alexma
    Alexma Member
    103
    SoCal Chino Hills
    3M makes a great kit that includes a pad and "sandpaper" with polish.
    Works great, It goes for under $30.
    You could probably do 2 cars with it.
  13. Dusty Chips
    Dusty Chips New Member
    85
    Laughlin NV
    Automatic car wash disease.
  14. babybird
    babybird Member
    117
    44
    Colorado
    I've used the Meguiar's on my '03 Subaru Legacy last year and it was like driving a new car. I was shocked at how much more light clear headlight lenses put out. Oncoming traffic appreciates it a lot too because there's significantly less glare from your low beams.
    But as someone here already stated, buffing out the lenses does pretty much destroy what's left of the UV protective coating on the lens, which means you're going to have to re-do the treatment every 6 months or so to keep your visibility unfortunately. Mine are already foggy again and I need to re-do them.
    You can blame the DOT for setting lousy standards that allow plastic headlight lenses to be used, because this wasn't a problem on cars back in the 70's and 80's when they were still glass (although breakage, weight, and manufacturing expense certainly were). I may be out of date, but I know at least up until the early 2000's the European equivalent of the DOT still required glass lenses for headlights.
    So I guess the real question is, does anyone know of a product similar to ZAGG's InvisiShield, or some kind of optically clear spray that blocks UV rays? Something like that applied to the lens after buffing them clear again would be ideal I'd think.
  15. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    Your auto parts dealer should have "BlueMagic" Headlight Lens sealer for new and restored lenses. Just tried it, so time will tell.[​IMG]
  16. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    The more expensive Meguiar's kit has a UV protectant product included in the kit. I believe it was $29.95 for the kit.
  17. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    Can't you just apply a sunscreen with a high spf?:D
  18. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Bullfrog Sunscreen so it's waterproof! :D
  19. Rest
    Rest Active Member
    1,210
    53
    CA
    I'd rather have glass headlight as well. Sometimes I had a cracked glass lens but rarely because they were pretty strong. Yes weight might be an issue, although slight. I have a hard time understanding there being a manufacturing expense higher than with plastic headlights. If that's true then certainly consumers are getting fleeced, because plastic lenses cost way more than glass ever did.
  20. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    The old glass lenses were small, square or round. They didn't have the intricate shapes that modern lenses do so to try and compare cost is kind of ridiculous. A glass lens in the shape of the Prius lens would be more expensive to manufacture than a plastic version. With so much surface area the glass lens would be subject to fracture and you would be hard pressed to buff out the scratches and chips. lol
