headlights go out monthly?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jnt4659, May 21, 2015.
  1. jnt4659
    jnt4659 New Member
    midwest
    We are newer to hybrids. We purchased a used 2012 prius approximately 1 year ago. Within the past year, we have replaced the headlights approximately 6 times. Last month we replaced both front lights and tonight, out of no where 3 lights burnt out (both headlights and 1 bright light). It was dark outside and we live in a rural area so we had to drive 90 miles with 1 bright and the 2 day time lamps. Just wondering if this is a common problem? We maybe have changed bulbs in other vehicles once every couple of years and this is a monthly thing with our Prius. They aren't cheap so it's frustrating. My husband has been changing the bulbs and he does not touch the glass. Any advice out there is greatly appreciated. Thank you.
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    There is a TSB-0204-12
    2010 Toyota Prius TSBs (Technical Service Bulletins) | ToyotaProblems.com scroll down to exterior lighting: headlights.
    Which addresses your issue. The wiring harness to the headlights is replaced.
    The TSB includes 2010-11 models, but it sounds like you are having the same problem.
    Merged Also, do you leave the headlight switch in the "On" position constantly, even when shutting down and starting the car?
    If so, try turning the headlights off, at least before starting the Prius up, before turning the headlights on again. Your headlights will probably last a lot longer.
    #2 xliderider, May 21, 2015
  3. Pat L
    Pat L New Member
    Three Touring
    Did anyone have a diagnosis for your problem?
    I’m having the same problems.
    Thanks Pat Lopez
  4. Grit
    Grit Senior Member
    6,148
    4,058
    Wilkes Land
    See post #2 first paragraph. Free fix if you need an incentive to read the post.
  5. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    Pat:
    Your profile says you have a 2009 Prius (Gen 2). I don't believe the TSB referenced above applies to Gen 2. Those cars that have HID headlights (i.e. those with factory fog lamps) are known to have bulbs that will fail after a number of years. If you find that your replacement bulbs are also failing, it's possible that the ones you are buying are not up to OEM standards or your ballast (also known as headlight ECU) may need to be replaced. There are many discussions regarding this issue on this forum. Here is one thread:
    HID headlight (cover too tight) help? | PriusChat
    I hope this helps.
