Headlights keep failing
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Uber driver, Oct 12, 2015.
  1. Uber driver
    Uber driver New Member
    San Jose
    My original headlights lasted almost 10 years now they die about every 6 weeks right side original die the 1 month later left side died now both have died 2 to 3 times. Is something wrong with the light system any one else have this problem.
  2. apt5020
    apt5020 Senior Member
    881
    1,294
    Prius City, CA
    Are you installing aftermarket HID? Did you touch the bulb with your finger tip? Wear glove and try not to touch the bulb when you install it. Which brand did you use. Just wondering.
  3. Uber driver
    San Jose
    Sylvania bulbs going to try different brand replacing bulbs is getting old may go to Toyota and get OEM bulbs original last long time
  4. xliderider
    xliderider Senior Member
    7,896
    3,129
    Honolulu, HI
    Isn't there a known issue with corrosion of the headlight wiring terminals in the bulb connectors?
    OP, check for corrosion in the connectors. That can cause poor conduction of the current to the bulbs and cause the premature failure you are having.
  5. kinglew
    kinglew Member
    318
    49
    ny
    2020 Prius Prime
    Same problem clean connectors and apply dielectric grease after clean .also take duct seal apply around connector to seal out moisture.also Sylvania are junk blubs OEM are Philips.syvania warranty blub one year . will send you free sets have received all have fail longest last nine months 9 days. Switch to Philips all well
    apt5020 likes this.
