Headlights too high?
Discussion in 'Gen 4 Prius Main Forum' started by BoltonJoe, Feb 7, 2017.
  1. BoltonJoe
    BoltonJoe Junior Member
    55
    Massachusetts
    I've only been driving my 2017 Gen. 4 for two weeks, and I love it. However, when driving at night using low beams, I've had oncoming drivers flash their brights at me--presumably because my headlights appeared to be aimed too high. Is this possible or likely?
    Thanks,
    Joe
  2. Steve McCracken
    Steve McCracken Junior Member
    33
    48
    I have a 2017 Prius Two and get the same thing.
  3. GTBaker
    GTBaker Member
    45
    ----Canada----
    They are just a tad too high.
  4. CuppaT
    CuppaT New Member
    UK
  5. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Aim them down a little or have your dealer do it for you, it'll help with that a lot.
    At least on the 2016s, the manual has headlight aiming directions for Canada, saying to use a Phillips head screwdriver, but that isn't the case on US cars. Use an 8 mm socket or wrench instead.
  6. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    Happily for me, I've not had that problem with my business edition (similar to US 3).
    kithmo likes this.
  7. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Me neither with the Excel, I don't think it affects rhd Uk cars.
  8. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    That's what I thought, but CuppaT is in UK!
  9. Mendel Leisk
    39,015
    Didn't they do something to the headlights, going into 2017? Not just re-aiming: something modified?
    But no recall of the 2016, sim. to the MIA mile/km switch, for example.
  10. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    Believe that was just north American models were modified. ProdigyPlace will know for sure.
    PS. UK model and maybe European one have self leveling headlamps.
    #10 RCO, Feb 8, 2017
    kithmo and Mendel Leisk like this.
  11. Prodigyplace
    Prodigyplace Senior Member
    11,706
    11,323
    Central Virginia
    Actually, they marked down the 2016 due to glare. Apparently the headlights were modified for 2017 and received a better rating.
    2016 - Excessive Glare & Poor rating
    2017 - Some Glare & Acceptable rating
    The only time I have been flashed in my 2017 Prius was on a road that had extreme up and down sections. I regularly drive on roads with more moderate slopes with no issue. It is possible the lights are mis-aimed. The dealer should be able to deal with it under the ToyotaCare warranty.
    Steve McCracken likes this.
  12. BoltonJoe
    55
    Massachusetts
    Thanks, all.
    The woman who sold me the car called to follow up, and I mentioned this problem. She said I should bring the car into the dealership and they'd fix it. Of course we're in the midst of a blizzard right now, so I'll have to wait a day or so.
    RCO likes this.
  13. Steve McCracken
    33
    48
    Good luck.
    krmcg likes this.
  14. au_prius
    au_prius Australian Prius Driver
    67
    55
    Australia
    In a different thread, someone pointed out that US Prius models don't have auto-levelling headlamps, whilst it appears most (all?) other countries get them, which might also be a factor with glare issues on US models, especially with heavy loads in the back seat and boot.
    Prodigyplace likes this.
  15. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    Are you suggesting Yankees are heavier than the rest of the world?
    joelg1988, au_prius and Sooner Al like this.
  16. Prodigyplace
    11,706
    11,323
    Central Virginia
    You had to pick the negative option huh?
    The city I work in is known as "The City of Seven Hills" I guess the UK is too small to have hilly roads. :D
    I am located in the foothills of the Blue Ridge Mountains.
    #16 Prodigyplace, Feb 11, 2017
    RCO likes this.
  17. jdenenberg
    jdenenberg EE Professor
    3,867
    1,866
    Trumbull, CT
    2020 Prius
    LE AWD-e
    When I first started driving my 2016 Prius I noticed that the headlights were aimed too high (so did on-coming drivers). I asked the dealer to lower them a smidge at the 6 month maintenance review. Problem solved.
    JeffD
    RCO likes this.
  18. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    Really, I'm a heavy guy but losing weight for potential surgery. I'm under 100kg ATM and hoping to get lower and it's not easy with a hearty appetite like mine. Still my waist is mid 40"s and needs to be much narrower for my height. Country roads in Cornwall are twisty and up n down like the proverbial. You're no sooner down one than you're struggling up another they're not so high but there are lots of steep sided river valleys and tight curves to contend with. Of course, you don't see much of that in Poldark, well, not the roads anyway.
  19. au_prius
    67
    55
    Australia
    Haha! No that wasn't quite what I meant :)
    Any car that has a fully loaded trunk / boot and passengers in the back will naturally be rear heavy, hence the need for auto levelling. It would be nice to even have manual levelling at least.....
  20. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    I guessed that, I was just teasing. ;) but that's why I tend to sit in the front row anyway! :cool:
