Headlights turn off randomly
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by vef579, Nov 24, 2014.
  1. vef579
    vef579 Junior Member
    2004 Prius.
    Sometimes, quite randomly, the headlights will turn off. Sometimes its both, sometimes its the left only, and sometimes its the right only. This affects both main and high beams. The dash lights and tail lights may still be on (panicking doesn't give me time to confirm that), but for sure the Nav panel is still lit.
    The first time this happened was when I was driving on a mountain road at night in the rain. It now happens almost every night and I have confirmed that it also happens in daytime. Road conditions (bumpy/smooth, wet/dry, dark/well lit) do not seem to be a factor.
    At least once while still in my garage, when I started the car the left light was out.
    I can get the lights to turn back on by turning them off all the way and then back on. Nothing else works.
    I have replaced the relay for the lights - that didn't change anything.
    Any ideas?
  2. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    once I changed the bulbs, the problem went away
    you can buy them on Amazon a lot cheaper than Toyota
  3. vef579
    Thanks. I'll give it a try.
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    You don't say if you have the 2004 with halogen or with HID bulbs. If you have the HID bulbs, that means the bulbs need to be replaced.
    Read this: Not all HID Bulbs are created equal | PriusChat
    Especially the part that says:
  5. Ricky Bolan
    Ricky Bolan New Member
    Olympia
    My headlight would shut off on the passenger side and sometimes both lights would go out turning the switch on and off would make them come back on this attracts attention and works good if you want to get pulled over and harassed.
    I purchased an HID kit from ebay for $39.00, on the bottom of the headlight assembly on each side is an aluminum cover that contains the power supply. The bulbs had a plastic base that had to be carved down to size to fit the prius. The ebay add claimed it fit the prius it didn't fit out of the box. Be careful when grinding the base to hold the wires out of the way and don't grind your fingers which goes without saying. There is a black and red wire that has wide spade terminals they are too wide to fit the connector that plugs into the prius power supply and leads to the headlight bulb access cap. The Spade terminals could be cut off and smaller ones crimped on I ground them down and shortened them with a grinder. The plastic cap that covers the opening to access the bulbs has an arrow that lines up with a a vertical line on the housing the wider line is where it opens, it is difficult to rotate. Once the arrow and the mark are lined up pry it off with a screw driver.
    The compartment where the power supply is located has a triangular plastic sheet that has to be cut out to insert the new power supply which can be attached with the provided double sided tape to the bottom of the cavity, the original power source was attached to the aluminum cover with screws. Four screws attach the headlight assembly to the car body. There is one bolt behind the inner fender that attaches the bumper cover to the fender, 2 plastic fasteners under the hood that attaches the bumper cover to the radiator support, and two screws with rubber bumpers that the hood rests on when closed. Pull the bumper cover away from the fender it will expose a black plastic part attached to the fender with screws in it, these screws are not necessary to remove the bolts you need to remove are below in the metal the other two headlight bolts are easy to find.
    Best of luck if you try this fix it worked for me and I like the bright white headlights my old ones were yellow.
