Headlights
Discussion in 'Gen 3 Prius Main Forum' started by ptwebber, Dec 12, 2020.
  1. ptwebber
    ptwebber Junior Member
    Santa Monical CA
    I have noticed some Prius’s that drive by have a right side headlight that is noticeably dimmer than the drivers side. Mine is like this when I pull into the garage you can really see the difference in the light pattern. I see other Prius’s going down the road and it seems they suffer the same problem. The lens is clear and I have tried stock replacements, and after market and the right side is not bright enough. Any ideas or fixes?
  2. StarCaller
    StarCaller Senior Member
    1,278
    730
    Cedar Crest, NM, USA
    try a relay harness which gets connected directly to the battery /
    (but before doing that I would first disconnect/clean/check ALL headlight connections & maybe wiggle the fuses a little bit)
  3. orenji
    orenji Senior Member
    5,887
    3,488
    Do you have JDM headlights without the amber side markers?
  4. dckeener
    dckeener Junior Member
    Maryland
    I opened up my headlights and replaced the projectors with Lexus ones when I upgraded to hids and one of the old projectors was all funky inside. Looked like it got too hot and the reflective coating was all peeling. That would definitely cause dim output.
  5. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    407
    2013 Prius Plug-in
    Where can I purchase these without getting on a flight overseas to purchase them?
