Headunit firmware upgrade
Discussion in 'Gen 3 Prius Audio and Electronics' started by JackSmith, Aug 27, 2022.
  1. JackSmith
    JackSmith New Member
    New York
    My dad got 2013 model with headunit model 57034. He doesn't use any of the apps on it. Main usage is connecting the phone with bluetooth for handsfree calls and music streaming. The version of software is 2.1.0. The problem is sometimes the car doesn't connect and requires re-pairing the phone. I read in a few thread similar problems were fixed by upgrading the headunit firmware. Seems it can be upgraded to 5.2.0. Seems in the past we used to be able to download the firmware package from
    Code:
    toyota[dt]com/firmware-updates/download
    (sorry can't post links yet)
    Unfortunately Toyota seems to have pulled the packages for Gen 3 Prius.
    Does anyone have the update package or knows where can I download it from?
  2. ASRDogman
    ASRDogman Senior Member
    7,821
    3,983
    You might try going to a toyota dealership and ask them if they have it.
  3. JackSmith
    New York
    Leaving this here if someone stumbles upon the same question. Going through a lot of old threads I figured that the file name for the update file is named 01039-HBEKR-16A.zip. Using all my search engine fu I was not able to locate the file anywhere. Today morning I had a lightbulb moment that it may still be available on Toyota website. I picked 2016 model, grabbed the link and changed the last part to my file name. And voila, I was able to download it and successfully apply the upgrade on my car.
    Code:
    toyota[dt]com/firmware-download/01039-HBEKR-16A.zip
    J Smith, Isaac Adams and usafxai like this.
  4. Isaac Adams
    Isaac Adams Junior Member
    Thanks @JackSmith - this is a great hack. I was able to download the file as well :)
  5. Vladimir-K
    Vladimir-K New Member
    Russia
    Привет, подскажите там лележит образ iso. Как мне прошить его в магнитолу
  6. ASRDogman
    7,821
    3,983
    English....
  7. ChapmanF
    18,546
  8. Vladimir-K
    Russia
    Hello, tell me there is an iso image. How do I flash it into the radio
    Is there a translator, or do you not know how to use it?
    У меня Приус Япония 2015 года с правым рулем. Радио стоит 100039, думаю это обновление подойдет
    #8 Vladimir-K, Mar 20, 2023
  9. J Smith
    J Smith New Member
    Arkansas
    Hey Jack, fellow Smith here. Have a 2013 Prius that is currently on version 2.2. Bluetooth has been constantly not connecting to wife's iphone/spotify and I'm getting quite an earful. Since Toyota no longer lists 2013 software I tried your trick and it did download the file. i'll try this install and let you know how it goes.
  10. doctorman
    doctorman Member
    210
    36
    NY 11020
    does anyone know if 57034 uses the same firmware as the 57011 (unit form 2012 prius v with HD radio)
    Update:
    the same entune 5.2 file that is going around for many toyota cars works fine on 57011
    #10 doctorman, Mar 11, 2024
  11. whitrzac
    whitrzac Junior Member
    46
    madison
    I just used this to update my 57011 as well.
    Didnt recognize my 32gb flash drive and I had to use a smaller one.
  12. SlidingBike
    SlidingBike Active Member
    171
    113
    Fremont, CA
    Can I use this for my 2012 Prius 3 (Radio number: 57032) ?
  13. cmd
    cmd Junior Member
    US
    Four Touring
    I have the file, can you please tell me how to do the update? Toyota says to follow the instructions link, but I don't see one. Thanks.
  14. BoydII
    BoydII Junior Member
    OK
    I need to do this too. Does anyone have any instructions anywhere?
  15. BoydII
    OK
    I just managed to get this update updated. It was very easy.
    1. Get the 01039-HBEKR-16A.zip
    2. Extract the.ISO file and put it onto a blank flash drive. The one that we used was 64 GB.
    3. Plug the flash drive with the ISO file Into the USB slot. Mine was located in the armrest.
    4. Start your car and go to apps, general, software update. It automatically asked if I wanted to update the software before I finished that process. I told it yes and then confirm. It took
