Healthy auxiliary battery but cannot start
Discussion in 'Prius c Main Forum' started by vox_, Oct 16, 2021.
  1. vox_
    vox_ New Member
    NZ
    2015 Prius c
    2015 Prius C and has been driving well everyday around town and suddenly cannot be started a couple hours after parking.
    Remote key doesn't work - key battery checked and replaced.
    No dashboard, electric window, audio or anything, just the engine light.
    However, the 12V battery is healthy - reading 12.65Volts off-load.
    Can be jump started, but dies when turned-off, even after driving 20km.
    No blow fuse. But hearing relay clippings and wired squeezzing sound likely from the engine controller in the hood.
    V strangely, the car started successfully for one time, after left the key at "ON" for 5 minutes. No luck since then.
    Anyone else has experienced this before?
    Any help is appreciated.
    Cheers,
    Alan
  2. vox_
    vox_ New Member
    NZ
    2015 Prius c
    a follow up - the 12V charges okay to 13.6V and can hold that voltage for at least couple of days.
    However, once connects back to the car, it drops to just 6V.
    Any suggestions?
    Cheers
  3. topshot
    topshot Member
    145
    57
    Midwest
    2015 Prius c
    Replace the 12V.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    That 13.6 is the charging voltage and NOT the battery.
    You need a new battery.
