Heat from the Sunroof?
Discussion in 'Gen 3 Prius Main Forum' started by JarrettOriginal, Jun 14, 2017.
  1. JarrettOriginal
    116
    81
    North Hollywood
    Now that the summer heat is kicking up in LA, and that I've been having to park in the Sun for the past few days, I'm noticing a lot of heat coming down from the sunroof, even though I keep everything closed up.
    Would putting a ceramic UV liner on the window do anything to help the heat?
    Or is it just damned hot due to the sunroof being on the roof of the vehicle giving it maximum exposure to that big ol radiation battery in space that both gives us life and also makes me slightly uncomfortable in my vehicle?
  2. Maarten28
    Maarten28 Active Member
    414
    224
    Netherlands
    It's glass and sunlight passing through glass will heat surfaces and that heat won't pass through glass as easily. Simple as that. The heat generator is not UV (UV causes sunburn) but IR. So you need a block for IR light. Or just darken the sunroof alltogether.
  3. magnumrtawd
    magnumrtawd Member
    305
    71
    Toledo,Ohio
    One of the joys a a sunroof! Wait till it starts leaking!
  4. ChapmanF
    15,581
    I had a leftover swatch of bubble radiant barrier that I just tossed up on top of the sliding shutter. Helps a bit.
    -Chap
    JarrettOriginal likes this.
  5. CoastRider
    CoastRider Active Member
    305
    397
    Off into the sunset...
    My current Prius doesn't have a sunroof. But my last Toyota vehicle did. And it got hot as H. I had the tint shop put the darkest tint they had on the sunroof glass. It helped somewhat, and it reflected UV , but it was still very hot.
    I can't figure out why some of these guys put that black plastic wrap stuff on the roof of their white car. Man, you talk about attracting heat!
  6. JarrettOriginal
    116
    81
    North Hollywood
    That's a great idea, thanks!
  7. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    A gold flashed tint will block the IR. They use it in the record challenging EVs. I find it hard to believe that the glass sunroof is any different than the metal roof however. Perhaps the lack of any insulation is the difference.
  8. Estes Kefauver
    Estes Kefauver Junior Member
    One of these days, I'm going to have to figure out how to run that solar-powered ventilation feature ... is yours not working, Jarrett?
  9. David Beale
    5,963
    1,981
    Edmonton Alberta
    Solar powered ventilation:
    Just push in the button and leave it in. The system will run when it gets hot and the car has been off for about 5-10 min. Hot as in above about 15C. Leaving it on has no other effect, other than perhaps putting slightly more wear on the fan bearings, but the fan runs at a lower speed, not full speed. Oh, and I suppose the cabin filter will accumulate more dirt.
    Estes Kefauver likes this.
  10. ChapmanF
    15,581
    I read the original post as complaining not about the accumulation of heat while parked (which the solar vent can help with), but just the relentless radiant heat from the sunroof shutter beating down on the head and shoulders while driving (which a radiant barrier does help with a little).
    -Chap
  11. Yippeekyaa
    Yippeekyaa Active Member
    137
    160
    North Carolina
    Sunroof Prius owner here. Got tired of the heat and the road noise from the uninsulated roof. Dropped the headliner and installed some sound proofing and a radiant barrier. Now I can't even hear raindrops on the roof when parked when previously it sounded like marbles pelting the roof. While I had the headliner out I removed the factory rear dome
    Light and it's awkward bracket that was lowered to make room for the roof and installed new lights next to the roof grab handles. Gained 2 inches of headroom.
    Curiously, the panel for the sliding cover under the sunroof is made from the actual roof panel cut out to install the sunroof. Color matched and I could see the cut marks and lines drawn to make the cut right.
  12. JarrettOriginal
    116
    81
    North Hollywood
    No, that works fine, but that's only on while parked, it doesn't have anything to do with heat coming down on me while driving.
