Heat or A/C?
Discussion in 'Newbie Forum' started by p1cfl01, Oct 27, 2008.
  1. p1cfl01
    p1cfl01 Junior Member
    New York
    When wanting to turn on heat, do I use the A/C control or the AUTO control without turning on A/C?
    Both can be used and heat will come out, but not sure which one is best for the car.
    Thanks
  2. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    Either way will work. There is no one way that is best for the car. I just set ac auto on some comfortable setting, and let it do its thing. In the early morning on a cold start, I may switch it off until the engine builds enough heat normally. Having a high heat setting will run the engine more if its cold to create the heat. The main thing is, make yourself comfortable, the car will figure the rest out. If you just want ambient outside air, go to the climate screen, switch AC off, and select the fan speed and temp you want (I use LO for most California mornings). Its all pretty much the same, regardless, depending on your temp setting. It sounds more comfusing than it really is.
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    I use auto A/C year round with the AC selected. The compressor is electrically driven and will only come on when necessary. It also keeps the windows from fogging. Just use the temperature control to set your comfort level and let the auto system work as designed.
  4. p1cfl01
    New York
    That's what I thought, just want to make sure I'm not burning out the A/C to run heat....
    Thanks all..
  5. richard schumacher
    7,663
    1,038
    United States
    Keep in mind that in the Prius "A/C" really does mean "air conditioning" and not "air cooling". If you turn on AUTO it decides which outlets to open and how fast to run the fan; all you need do is set the temperature. Beyond that you can manually set/override as few or as many things as you like.
