Heat shield coming off
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by icyrius, Aug 17, 2021.
  1. icyrius
    icyrius Active Member
    238
    114
    Florida, USA
    2014 Prius v wagon
    My son sent me the attached picture of his Prius and it appears a heat shield is coming off his car.
    i have not taken a look at it yet. But I want to buy the parts before I get to his house.
    Can this be re-attached with bolts or does it use some type of rivet?
    I have also attached a picture of the part I suspect is falling off that I found in this great forum.
    thank you for your help
  2. xliderider
    xliderider Senior Member
    8,055
    3,222
    Honolulu, HI
    That heatdhield gets removed when installing a catalytic converter anti theft shield.
    There must be a lot of them around. Mine is in the back of my garage gathering dust.
    If your son lives in an area that has catalytic converter thefts from Prius vehicles, then he should consider installing an anti theft shield.
    #2 xliderider, Aug 17, 2021
  3. xliderider
    8,055
    3,222
    Honolulu, HI
    The shield is held on with 4 large sized plastic push pin panel clips, or whatever they're called.
    You don't need to buy a new one, just pick up some of the clips from the dealer, show them your picture of the hanging shield and they will know what size you need. There are 4 of them that go across the front of the shield in the 4 large holes, into the corresponding holes in the car frame.
    #3 xliderider, Aug 17, 2021
  4. xliderider
    8,055
    3,222
    Honolulu, HI
    You can see where the clips go on the original shield by looking at the position of the 4 large rivets on my cat shield installation. Keep in mind that my picture is a mirror image, flipped left/right along the front to back axis of the car.
    icyrius likes this.
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,352
    2,346
    Taylors, SC
    M5 rivet nuts will fit the holes with no drilling. M5 bolts with fender washers would be a permanent fix.
    icyrius likes this.
  6. icyrius
    238
    114
    Florida, USA
    2014 Prius v wagon
    Thank you for your help!
  7. Mendel Leisk
    40,574
    #7 Mendel Leisk, Aug 18, 2021
    xliderider likes this.
  8. Georgina Rudkus
    3,352
    2,346
    Taylors, SC
    Four 1/4 inch large flange aluminum rivets is another "permanent" solution.
  9. icyrius
    238
    114
    Florida, USA
    2014 Prius v wagon
    I went to my local Toyota dealer and they wanted $5 a piece. The service guy was nice enough to recommend me to get them somewhere else and showed me a sample part.
    I found these in Advanced Auto Parts for $3.99 a pair. It was a perfect fit. I posted a picture of the package just in case someone else runs into this same problem.
  10. Georgina Rudkus
    3,352
    2,346
    Taylors, SC
    They are 7mm. Others like Nissan use 8mm, which is the most common.
    icyrius likes this.
  11. Rebound
    Rebound Senior Member
    3,972
    2,626
    Portland, OR
    $6.99 for a hundred on Amazon. There are several variants of these; one will have the clips you’re looking for:
    Ginsco 102pcs 6.3mm 8mm 9mm 10mm Bumper Push Fasteners Rivet Clips Expansion Screws Replacement Kit
  12. Mendel Leisk
    40,574
    I just get the Toyota fastener, avoid runaround, possible repeat of the dragging on the road factor.
    if you stay on top of what’s happening on the underside, it’s pretty rare to have problems.
    boils down to the price of a Starbucks coffee or two, maybe once per decade.
  13. xliderider
    8,055
    3,222
    Honolulu, HI
    I'm thinking of installing some stainless steel threaded inserts (rivnuts) and using stainless screws to hold everything in place.
  14. Mendel Leisk
    40,574
    Overkill. The plastic fasteners are pretty solid. If you’ve managed to scour the underside enough to break that panel loose you may have other damage. They will not come loose with normal conditions. I recall the first time I took that panel off: the fasteners were really locked on.
    it’s always tempting to go Rambo, but rarely warranted. Sometimes super tenacious fasteners can lead to bigger issues: ripping out body sheet metal.
  15. Rebound
    3,972
    2,626
    Portland, OR
    If you’re going to do that then just install a cat shield, I think.
  16. xliderider
    8,055
    3,222
    Honolulu, HI
    Already done, I was referring to the main underbody panel up front. Most of the fasteners are screws and bolts already, but there's still a few plastic rivets/plugs.
    Georgina Rudkus likes this.
  17. Georgina Rudkus
    3,352
    2,346
    Taylors, SC
    Putting these under even the M6 washer head bolts will keep the heads from wearing through the thin plastic. The neoprene surface of the washer is more compatible to the soft thin polyethylene plastic from which the undercovers are made.
  18. Rebound
    3,972
    2,626
    Portland, OR
    I bought the 100 for $7 kit from Amazon. Mine has the underbody fasteners and the door panel fasteners. Great value. They definitely work.
    Mendel Leisk and xliderider like this.
  19. Mendel Leisk
    40,574
    Wash those fasteners out with soapy water whenever you remove them, maybe work the mechanism back/forth too, whenever you have them out. Grit accumulates, jams the mechanism, can cause them to seize and break. Another factor is you don't manage to corral all the jaws, one stays outside the hole, bends back, eventually fails.
