Heat Shield Rattle - Separated at Bolt, $300 to fix?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by woody23, Jun 20, 2023.
  1. woody23
    woody23 Junior Member
    69
    I was at the dealer and they informed me my heat shield needed attention, and it would be $300 to install a new one. That seems super high to me.
    It's separated but still fairly stable, it's not hanging to the ground or anything. What would be a simple fix for this if the bolt is still attached?
    Picture attached.
  2. Mendel Leisk
    40,586
    Fender washer.
    CR94 and woody23 like this.
  3. Leadfoot J. McCoalroller
    7,861
    7,329
    Pennsylvania
    2018 Prius c
    Found your problem.
    It is super high at the dealer. They only have brand new parts and they charge the highest rates for their labor.
    But there's nothing special about an exhaust heat shield, any mechanic can address that. You'll still be stuck paying for a half hour, maybe an hour at their rate, but it'll be lower.
    woody23 likes this.
  4. woody23
    69
    Any idea what size, by chance? I couldn't actually get under the car (yet). I had to slide my cell phone underneath the car and screenshot the video.
  5. Leadfoot J. McCoalroller
    7,861
    7,329
    Pennsylvania
    2018 Prius c
    You'll want one with about a 3/8" hole, maybe 1-1/4" diameter. (I don't think I've ever encountered a metric fender washer!)
    woody23 likes this.
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,353
    2,347
    Taylors, SC
    3/6 inch is too large. The fastening stud and matching nut is M6x1.0. That works out to 1/4 inch.
    These would be ideal.
    MECCANIXITY Bonded Sealing Washers 25x6.3x2.8mm Stainless Steel EPDM Rubber Backed Screw Gasket
    The neoprene washer would firmly grip the partial surround of the thin aluminum shield and fully eliminate any rattling.
    #6 Georgina Rudkus, Jun 20, 2023
    woody23 likes this.
  7. woody23
    69
    Thanks guys, I really appreciate the help.
  8. Mendel Leisk
    40,586
    Be careful backing out that bolt; maybe apply some penetrating solvent first, let it soak.
    woody23 likes this.
  9. woody23
    69
    I will do that then. Thanks Mendel!
  10. Tombukt2
    Tombukt2 Senior Member
    12,214
    2,155
    Durham NC
    I removed all mine haven't a problem since on a10 and a 13
  11. Mendel Leisk
    40,586
    They did put that heat shield there for a reason though. A blown fastener or two is easy to fix.
    Georgina Rudkus likes this.
  12. Eddie25
    Eddie25 Active Member
    490
    207
    MI
    I used aluminum flashing cut in squares with scissors (about 2.5" x 2.5") (made the hole with a drill) as washers to fix multiple rusted out heat shield connections about 4 or 5 years ago. They are still fine to this day. I spray them with fluid film once in a while.
  13. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    If you depend on a Toyota Stealership for trivial things like this, the cost of operation of your vehicle over a lifetime will be outrageous. Find yourself a friend or family member that you can rely on in situations like this. You just put a big washer there and problem is solved... The stealership on the other hand are warranty specialist who sell massively overpriced parts and will always repair to a brand new condition at the maximum price possible.
  14. Georgina Rudkus
    3,353
    2,347
    Taylors, SC
    The bonded neoprene to stainless steel washers are great to prevent "saw through" with movement of the soft plastic panel mounting holes bu the steel mounting bolts, even those with "keps" washered heads.
    The neoprene washers have close the same durometer hardness as the polyethylene panels and will be less likely to "saw through" them. If one would remove one of the panel bolts of a car with miles on it and examine the panel under the head, the owner would notice that the indentation and "saw through" process has already begun. Given time, the washered head of the bolt would eventually be cut out like a cookie cutter.
    The larger fender washer can even be used, if the hole had been cut out and hanging loose under the car.
