Heat sign flashing
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by mytoyota, Dec 8, 2020.
  1. mytoyota
    mytoyota New Member
    Scotland
    Hello
    I've a Toyota Prius 2016 (Gen 4). For last few days I noticed that heat sign starts flashing for few seconds while I'm driving and then it disappears before flashing again. It almost always happens when I start the car in the morning.
    I've made a video
    Any suggestions?
    Thanks.
    #1 mytoyota, Dec 8, 2020
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    901
    504
    Cow-lee-fornia
    2023 Prius
    Blown head gasket. No, the radiator is low on coolant. You should get it checked out because that means that its leaking somewhere. Most likely at the part that is connected to the exhaust pipe.
  3. jerrymildred
    jerrymildred Senior Member
    11,513
    14,115
    Tampa, FL
    Yup!! Better get that coolant system checked out like yesterday. Hopefully, it's not too late to prevent a warped head and a blown head gasket. If the engine coolant it low, top it off with the pink Toyota SLLC. Don't just throw in water or (worse yet) some random and possible incompatible coolant.
    It would appear that you have a leak somewhere. Hopefully, just a hose or fitting. Could be a head gasket, though. But it seems odd that it would happen soon after start-up.
    alanclarkeau likes this.
  4. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    Or - it could just be a sensor problem. I had one go bad on a VOLVO - it told me that I was overheating, but fixing the dodgy connection fixed it.
    I'd get it checked either way. As Jerry suggested - yesterday.
    I also notice the Passenger Airbag light on - is there a story with that?
    jerrymildred likes this.
  5. orenji
    orenji Senior Member
    5,884
    3,486
    Your probably just low enough that it trips the
    Sensor and goes off as it warms up - probably need to top it off.
    krmcg likes this.
  6. mytoyota
    mytoyota New Member
    Scotland
    Thanks for your replies. I'll start off with getting coolant checked out.
