Heated steering wheel question
Discussion in 'Gen 4 Prius Main Forum' started by alam99, May 29, 2021.
  1. alam99
    alam99 Member
    97
    33
    Chicagoland
    Hi All,
    My 4th gen Prius has a heated steering wheel and yesterday was my first chance to use it. My question is:
    Is it normal for the 12:00 position to not heat up? I found the 2:00, 4:00, 8:00, and 10:00 positions did warm up. If it’s normal, so be it. If not, I would like to confirm so I can take it into the dealership.
    Thanks!
  2. Tideland Prius
    16,195
    Yes. Unfortunately, it only heats the sides of the steering wheel. The top and bottom are unheated.
    Pulse07 and alam99 like this.
  3. MIkeDr
    MIkeDr Active Member
    252
    137
    Seattle, WA
    2020 Prius
    XLE AWD-e
    I suspect Toyota uses the same basic element throughout all its vehicles, including those with wood on the top and bottom where heating isn’t desirable.
    49,693
    it's probably an aid to where you are supposed to hold it for safe driving
