heater/ac question
Discussion in 'Gen 3 Prius Main Forum' started by Dominic, Aug 24, 2010.
  1. Dominic
    Dominic New Member
    Halifax, Nova-Scotia
    juste wondering, when you start your car in the middle of the summer, if it is set on automatic, the A/C will automatically start and cool down the car. is the opposite SUPPOSED to happen like that also?
    i just noticed, it is starting to get a little colder here at night, and when i get in the car in the morning it's kinda chilly and definitely below the set temperature. however, the heater does not seem to start on its own. i was wondering if it is normal, if there is a delay before it actually starts or what's going on...
    can anyone shed a light on that?
    thx
  2. dwhutch
    dwhutch New Member
    Los Angeles
    The ICE has to warm up. The system will not turn the fan on until some heat can be delivered. You should notice the fan coming on after you drive a bit
  3. Dominic
    Dominic New Member
    ok, i'll try it tomorrow morning... how long does it usually take? or does it depend on outside temp?
  4. dwhutch
    dwhutch New Member
    Los Angeles
    Within a minute or so. I am sure outside temp have an effect. The system is monitoring the coolant temp. The fan will start slow and increase in speed as the ICE warms up.
  5. Dominic
    Dominic New Member
    hummm ok then if nothing actually starts, does that mean that i have a problem with the heater? 'cause i know for sure that i have waited longer than 1 minute and nothing happened... :-/
  6. Colonel Ronson
    Colonel Ronson New Member
    443
    33
    Tucson, AZ
    Um this is the same in any car you drive. Anyone who has driven a car should've figured out turning on the heater right away on a cold morning will do nothing but blow cold air. The heater will only start blowing in hot air when the engine is warm enough to start heating the air. A cold engine won't heat the car, and the heated air has to come from somewhere.
    In the summer, the A/C works by using the freon, which is available 24/7, regardless of engine temperature. That's what's confusing you. So its normal for the car to delay turning on the heater. It's just waiting for the heater block to warm up.
  7. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Some modern cars, mainly diesels, have a supplemental electric heater that starts warming the air from the vents within a minute or so.
    I suspect that the Prius has one too because slightly warmed air comes through the vents on mine after only about a minute even if the ICE has not yet run and it's in EV mode.
    Either that or the heat is from the inverter coolant.
    Perhaps someone who knows more tech about the Prius workings could confirm ?
    P.s. has anyone noticed that if you set the climate control to full heat (HI) and then turn it off then the heat still comes through, same with the Gen2 as well.
  8. Dominic
    Dominic New Member
    that's the problem with me.... it's not that i am not getting hot air, it's that i am not getting ANY air!!!
  9. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Have you tried adjusting the fan speed manually ?
  10. Dominic
    Dominic New Member
    yes, it works in manual mode, but nothing in automatic mode (but works fine in automatic for the A/C)
  11. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    try raising the temp more. If you got it set on 75 and it's 72 outside you wont notice much. If there is a bigger difference in the inside temp and what you have it set on it will turn the airflow to the footwells and blow hot air down there.
  12. Dominic
    Dominic New Member
    ok, tried it this morning, and after i cranked up the desired temperature to the max, i finally saw the car trying to heat it up... not too much success though. i wonder what it will be like in -30 Celsius temps! :-/
