Heater fan groan
Discussion in 'Gen 2 Prius Main Forum' started by qmanqman, Nov 1, 2025 at 2:42 PM.
  1. qmanqman
    qmanqman Active Member
    423
    143
    CO
    Now that it's cold and I got the heat on from time to time the fan will kind of make a groaning noise intermittently. Not very often but every now and then. Is there a simple and easy way to lube the fan without having to tear the dash apart and pull the Box out?
  2. Tombukt2
    Tombukt2 Senior Member
    12,840
    2,307
    Durham NC
    Getting time for fan motor no taking dash apart 3 10 mm move a piece of plastic . Blow out hole and vac it w shop vac. Put in new .
  3. pasadena_commut
    pasadena_commut Senior Member
    2,541
    757
    Southern California
    Does it make that noise if the fan is run and the heat isn't on? If not, it might be air in the heater core rather than the blower itself. I don't recall if the Prius has a valve that controls whether coolant goes through the core. On cars that do those sometimes make noises when the valve opens or closes. Same thing with blend door actuators.
