Heater Issue a
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Derek Cook, Feb 26, 2018.
Tags:
  1. Derek Cook
    Derek Cook New Member
    Buckeye, Arizona
    Hello, I am having a strange issue with my 2011's heater. I replaced the blower motor last week, because it stopped blowing air all together. Now, the Cold air blows strong, but the hot air blows really weak, even on the highest setting. The cabin air filter is new, I'm not too sure what else to check. Does anyone have any ideas? thanks.
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    how hot does it get and check for air pockets in your cooling system
  3. Derek Cook
    Buckeye, Arizona
    Air gets very hot, just doesn't blow out strong. How would I go about checking for air pockets? Thank you.
  4. jdenenberg
    jdenenberg EE Professor
    3,852
    1,852
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Blowing is a fan issue, air pockets in the coolant would cause no heating of the blowing air. Check for a clogged cabin air filter (it is behind the glove box). If that is not the problem you will have to have the fan motor retested and the wiring from the blower controller.
    JeffD
  5. Derek Cook
    Buckeye, Arizona
    Would the fan motor be to blame, even if cold air is blowing strong? I just replaced the blower motor, does it have separate settings for hot and cold? Thank you.
  6. jdenenberg
    3,852
    1,852
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I agree, the blower seems ok. That leaves a possible wiring issue by the technician.
    JeffD
    Derek Cook likes this.
  7. ChapmanF
    15,674
    I don't think there's separate wiring to the fan for heating and cooling. If it blows for cooling, it's wired. And the cabin filter is probably not switching from clogged to unclogged based on heating or cooling either. One thing that does change between heating and cooling mode is the airflow path. I think I'd be checking that the dampers reach their appropriate positions and there isn't some obstruction in there.
    Have you checked for any codes from the heater? No tool is needed, you just call them up on the heater's own LCD display.
    -Chap
    Bay Stater and Derek Cook like this.
  8. Derek Cook
    Buckeye, Arizona
    Thank you, I did not think of that. How do you call up codes on the display?
  9. ChapmanF
    15,674
    If I remember right, it's something like holding down auto+recirc while powering the car on. It's in a lot of posts if you search. (Sorry to be hasty ... I'm designated snack bringer for a rehearsal tonight....)
    -Chap
  10. Derek Cook
    Buckeye, Arizona
    Thank you! I will look that up!
