Heater not blowing warm air after long way downhill?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by DKTVAV, Jan 12, 2015.
  1. DKTVAV
    DKTVAV Active Member
    510
    101
    On my way back down from Big Bear mountain the heater stopped blowing warm air, just like outside air, before reaching the 10 freeway. I turned it to Max but still no warm air, what's wrong? It's working today on the way to work though but it's only less than 4 miles trip.
    48,985
    all i can think of is the engine turning to dissipate excess regeneration, (no combustion) and cold air blowing through the radiator. maybe if you put it in neutral, (illegal?) and use the friction brakes, the engine can run normally to produce heat.
  3. GregP507
    GregP507 Senior Member
    3,002
    480
    Right, when the engine is being used to dissipate energy, it's not burning fuel, therefore it's not producing heat for the heater. This is where electric elements in the heater housing would make sense. That would help dissipate excessive regen energy.
  4. DKTVAV
    510
    101
    It's not a good idea when going downhill from 8000' and also like you said "illegal".
    So is my electric heater not working?
  5. GregP507
    3,002
    480
    News to me if the Prius has it.
  6. bisco
    48,985
    they would make sense, but you don't have any. actually, they wouldn't make financial sense for toyota.
  7. GregP507
    3,002
    480
    So they said.
  8. bisco
    48,985
    i didn't hear them but i'll take your word for it.(y)
  9. DKTVAV
    510
    101
    So how to get warm? Plug in a portable electric heater?
  10. bisco
    48,985
    if you ride the brakes hard, the engine will run.
  11. GregP507
    3,002
    480
    Plug in where?
  12. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    The engine coolant temp would have to drop drastically to not have any heat. Assuming the coolant was up to temp, would the engine temp drop that much coming down the mountain?
  13. GregP507
    3,002
    480
    We either take him at his word, or we say it can't happen.
  14. bisco
    48,985
    i guess it would help to know the outside temp, the heater setting before starting down, how long he had been driving before starting down, how far down he got before the air turned cool, how fast he was going, if he's grille blocking...
  15. GregP507
    3,002
    480
    If you believe that grill-blocking works.
  16. bisco
    48,985
    i don't have any scientific data, but i believe it would help slow cooling of the engine if it's really cold out and you're at highway speeds.
  17. GregP507
    3,002
    480
    I'm sure it helps, it's a common practice here, but I'm skeptical it could account for much of a difference in this case,
  18. fuzzy1
    10,045
    Absolutely!
    Get a ScanGauge or other engine monitor, dial up the engine coolant temperature, and just watch it plummet. It won't drop to ambient, but it will fall sharply until a threshold is crossed and the engine is forced to burn some fuel.
  19. DKTVAV
    510
    101
    Cigarette lighter?
    I remember I used the brakes a lot to slow down and lot of traffic ahead.
    I started at the top of Big Bear mountain and immediately going down from 8000' so I don't know the engine is warmed up to temp or not.
    And yes, I use grill blocking but only haft of both parts.
    My stupidity: I have a scangauge but didn't remember to check the engine temp. I haven't looked at it for more than a year so I forgot it's there.
  20. GregP507
    3,002
    480
    I believe the Prius 12V lighter socket tops out at around 300W overall, so you may be asking for the moon there.
    #20 GregP507, Jan 12, 2015
