Heater
Discussion in 'Gen 3 Prius Main Forum' started by Manhal K Alrashdan, Dec 10, 2015.
  1. Manhal K Alrashdan
    Manhal K Alrashdan Junior Member
    81
    16
    jordan
    I wonder why the AC takes time to start heating on cold mornings.
    Actually. It gives warm air after about 5_10 minutes of driving.
    Is that OK?
    49,479
    no. what is the outside air temp? on a 37f degree morning, i start feeling slight warmth after 1 minute of 40 mph driving, and full heat after 4 minutes.
  3. Mendel Leisk
    38,720
    There's gonna be some lag, since the ventilation system gets its heat from engine coolant, which takes some time to heat up.
    How long this takes is the issue; if the car has significant miles you might have a failing coolant thermostat, one that's opening too soon, allowing coolant to flow to the radiator before it's heated sufficiently to warrant cooling.
  4. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    You can get and install an engine block heater if you have access to a nearby AC outlet. The preheated block and coolant will allow heat sooner and give you better mpg.
    Manhal K Alrashdan likes this.
  5. bisco
    49,479
    jordan temps should produce pretty quick heat without accessories, if the car is functioning properly.
  6. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    check coolant level maybe
  7. xliderider
    7,869
    3,116
    Honolulu, HI
    Hehe, sorry, I'm on tapatalk and don't see location info. :p
  8. Manhal K Alrashdan
    81
    16
    jordan
    I have 137K miles, actually, these days it's as cold here Jordan as the US, early moning it drops to 35-40. But I don't reach a speed of 45 mph, giving her time to warm up.
  9. Maarten28
    Maarten28 Active Member
    414
    224
    Netherlands
    5-10 minutes seems a bit long, but the heat for the car comes from the engine. So turning on the AC does do nothing to generate heat.
  10. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Assuming you have no mechanical issues...
    Just let the car warm up before leaving...you know, like other cars...and still get better mpg than the rest. I value my comfort far more than bragging rights as I work in the heat and cold already...but that's me.
    #10 frodoz737, Dec 11, 2015
