heating blows cold air
Discussion in 'Gen 3 Prius Main Forum' started by memento84, Oct 28, 2017.
  1. memento84
    memento84 Junior Member
    28
    Cleveland
    just noticed couple days ago, became apparent at 37F. air that comes out is cold, maybe little warmer than ambient. blower works ok. any ideas ? relay/fuse ???
  2. BZzap!
    BZzap! Senior Member
    1,607
    877
    Check your temperature setting ?
  3. memento84
    28
    Cleveland
    i have set it at HI , but also tried all settings 70-85F. so that is not it. any other ideas ?
  4. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Was the coolant changed recently? There may be an air bubble in the system. It's also possible the electric coolant pump has failed.
    I see you have a 2007 Prius, which is a GII. Unless you haven't updated your info. ;)
    Raytheeagle likes this.
  5. bisco
    49,397
    thermostat, blocked heater core.
  6. memento84
    28
    Cleveland
    changed water pump couple months back. heating was fine.
    blocked heater core - how to troubleshoot that ?
  7. bisco
    49,397
    waterpump is not the thermostat, is it? maybe need to read the coolant temp. not sure how to check the heater core.
  8. memento84
    28
    Cleveland
    1 clue - I could hear some gurgling noise, seemed like it was somewhere under the dash, but no leak ever (thought that was coming from engine compartment) - would that mean some obstruction in the heater core ??????
  9. bisco
    49,397
    gurgling might mean you need to bleed the system, but i'm not positive.
    Marcilla Smith likes this.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    If a Gen3: Have you checked the hoses and coolant in the overflow and they are warm?
    If a Gen2: have you checked the level in the radiator and are the hoses warm?
  11. memento84
    28
    Cleveland
    I will try to locate hoses for the heater core - it seems like a common problem (kind of), will try to blow it thru, opposite direction that it normally flows.
  12. memento84
    28
    Cleveland
    it is 3rd Gen.
    Coolant in overflow should be warm right ? the return one (upper) should be warm/hot right ?
  13. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    The overflow and hoses should be hot if the full warm up cycle has been completed;).
  14. memento84
    28
    Cleveland
    I checked that when replaced the water pump, and they were ok - will do it again! how hard is it to locate heater core hoses ?
  15. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    Water pump was replaced? How many miles? What was the cause of the previous pump failure?
    The easiest hose to check is the one off of the overflow reservoir ;).
    Keep us posted (y).
  16. memento84
    28
    Cleveland
    186k, pump died. so the return to overflow is heater core "out" ? will update asap
  17. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    The electric water pump died:(?
    Did you hange it yourself ? Get it back if not or ask what the failure was from?
    Here are 2 pics of water lines to check:
    Keep us posted(y).
  18. BZzap!
    1,607
    877
    Does the blower work?
    After all that’s said an done, it sorta points to a bad Blend door actuator. Almost all modern cars have the coolant circulatiing through the heater core constantly. The heat is controlled by opening and closing these doors with a motor that is controlled from the HVAC module. It’s all electronic. It’s also possible that the control head is malfunctioning.
  19. BZzap!
    1,607
    877
    BTW the coolant control valve is electronically controlled... no vacuum involved. This might be the source of your problem. You might want to turn the heater on and try gently tapping the control valve then check to see if you get heat. Another scenario is no signal from the controls. Fuse, maybe? Bad control module? Bad valve?
  20. David Beale
    5,963
    1,981
    Edmonton Alberta
    I'm still thinking he's got an air bubble in the heater lines, after replacing the water pump. Simple things first! ;)
