Heavy accelerating when ICE is cold
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Electric Charge, Oct 9, 2012.
  1. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    With the mornings getting colder now, I'm wondering if I should try to start driving using ICE so the engine is warm when I have to accelerate quickly when merging with fast traffic.
    My main concern is that typical gasoline engines don't appreciate being stressed significantly when the fluids haven't had a chance to warm up yet. Is this concern valid for the Prius ICE?
  2. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    If it's cold and you start the PIP, when you turn on the Heat to Defrost or heat the car, the ICE will start before you leave the driveway.
    Even though we want to save Gas, expect the ICE to run more than in the summer.
  3. Electric Charge
    545
    133
    Syracuse, NY
    Well that's the thing, I haven't been turning on the heat when I start driving. I used to rely on my remote starter with my other Toyota, but the Prius with heated seats does such a great job, I don't bother.
    52,062
    when i know i'm going to need hv, i try to hit it a minute or two before i need it. as temps get colder, i will hit it earlier due to prolonged warm up time until it's so cold, i need heat as ken said.
  5. PriusCamper
    PriusCamper Senior Member
    12,835
    5,202
    Pacific Northwest, USA
    Just drive it... The PIP has more ways to account for a cold engine than any other Prius. There was a highly detailed discussion about this a couple months ago regarding freeway driving with a cold engine. The PIP has some really smart ways of handling the problem... Do a search for the thread if you want more info!
    lensovet likes this.
  6. ngc4565
    ngc4565 Member
    193
    33
    Pennsylvania
    2023 Prius
    Unfortunately the science of internal combustion engines has not changed since the introduction of hybrid vehicles. Avoiding the use of the ICE and also having it ready at full capacity when needed are at cross purposes. It would be nice of the inverter cooling system could be used to heat the ICE, if it is not already.
  7. bisco
    52,062
    the ice has little power when cold, just like the regular prius. if you can warm it up before needed, you're better off.
  8. PriusCamper
    12,835
    5,202
    True... But the Plugin Prius has a much more powerful electric motor that intentionally throttles back the ICE when it's cold... Even at highway speeds...
    And more to the point if you're driving a shorter distance than it takes your engine to heat up... you're driving the wrong vehicle... (I don't listen enough when I tell myself that) Why not look into skateboards, scooters bicycles, jogging, etc.
    I went nine years without owning a car once. It's an entirely different state of mind! A one worth looking into from time to time!
  9. Electric Charge
    545
    133
    Syracuse, NY
    Alright, so it looks like this was definitely a good question. Will try to find that other thread as well. The hypermiler in me has been avoiding ICE, and now that it's getting cold, I was concerned I would be abusing the engine (nothing in the manual about it).
  10. bisco
    52,062
    same here. i only use ice one or two days a week for long trips.
  11. bisco
    52,062
    not sure who you're addressing this to, i drive 15 miles per day on a regular basis.
  12. rockerdan
    rockerdan PiP Rocks!
    427
    83
    Wheatfield NY
    as a side note of oldshcool ICE thinking....these new thin synthetics even in winter will produce good top end oil pressure just about instantly. Nothing like the old days where you truly HAD to let the car idle abit in cold mornings til dyno oil would get to the top end and stop the "ticking".
    I would simply push HV button a minute before the hwy power is needed on VERY COLD mornings. But for these fall temps there is no problem waiting IMO.
    Dan
  13. PriusCamper
    12,835
    5,202
    What's great is that with a plugin you can drive 15 miles a day
    Yea... You're right... A PIP doesn't need the ICE for short distances... I was referring to regular Prius, which isn't what this discussion was about! Apologies...
  14. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    146
    Fort Worth, TX
    I work 3 miles from home. I would love to be able to drive a small electric scooter to work. However, I also have to drop off my two daughters at school. One is 6, the other 9. I don't think scooters or bicycles are going to work well for that.
  15. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    The electric motors of the Plug-in and Liftback are the same. The actual difference is that the larger battery pack of the Plug-in is able to deliver more power.
