Heavy steering
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by defrankond, Dec 17, 2014.
  1. defrankond
    defrankond Member
    217
    23
    North Dakota
    does anyone else have a heavy steering feel on their 2010's with the 215 45/17 tires? It seems much heavier than previous Prius's and also have noticed that mine when it is really cold the steering wheel gets a little twitchy until it is fully warmed up
  2. JC91006
    16,482
    8,397
    The steering on my 2010 v is also pretty tight. I think it's normal. However i don't have the twitchy feel
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I'm on my THIRD steering motor. The other two failed in the taxi work at approx 30k mile intervals. There were two versions of steering motors on the early gen3's and the cheaper one used on the lower spec models (UK t3) was unreliable. The one used on the top 2 models is much better (UK models t4 & t-spirit). I believe in 2011 all Prii got the stronger motor.
    When mine failed it would almost judder like a normal car would when the steering fluid was low. It starts doing it occasionally and just gets worse and worse. It mainly happened when going from lock to lock quickly but then started happening more and more often.
  4. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    I may be wrong but I believe the V level (Five beginning with 2011 model years) is equipped with a quicker steering ratio that may contribute to higher steering effort.
  5. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    First, try adding air to your tyres. It may help a lot. The hint is when cold, the tyre pressure is lower.
  6. defrankond
    defrankond Member
    217
    23
    North Dakota
    It is a jutter type feeling. In fact at first I thought steering fluid was low but no idea where to check the fluid. As far as quicker steering response yes it does have that. In fact lock to lock is only 1-3/4 turns of the wheel in either direction from center. My last prius was a little over 2. I've only noticed it when it was really cold out with the juttering though. No power steering light comes on however. It comes on when the car is first started but then goes out signaling everything is ok
  7. bisco
    49,455
    is it different, at different speeds?
  8. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    The power steering is electric.
    There is no reservoir to check.
  9. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    223
    Nature coast, Florida
    Three Touring
    I too have the 17's. I was used to my '07 Touring, but when I switched to the Gen III, I immediately noticed the heavy feel. I am sure the low profile 17's have something to do with it...
  10. defrankond
    defrankond Member
    217
    23
    North Dakota
    No happens at any speed. And not always all the time.
  11. bisco
    49,455
    doesn't seem right, i wonder if the steering motor could be an issue?
  12. defrankond
    defrankond Member
    217
    23
    North Dakota
    Seems to be a expensive repair. Could this be something at fault with previous recalls?
  13. Mendel Leisk
    38,711
    I don't notice much if any diff, going from 215/45R17 pilots to 195/65R15 xice.
