heavy vibration of engine on idle
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Umar Ali, Jun 8, 2015.
  1. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    i recently noticed that when at idle, the engine is vibrating heavily. i know for sure it was really smooth and now as if there is something loose in there due to which it is vibrating. i dont know what is causing this i have always keep changing oil myself every 10k miles and transmission oil at every 30k. anyone have any idea what might have caused it and whats the fix
  2. JC91006
    16,482
    8,400
    maybe a misfire?
  3. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    I dont think it is misfire since i plugged in the obd device and check for any codes but didnt find any . or how can i find out if its a misfire/?
  4. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Do you use top tier gas with detergent? If not, your injectors may be dirty or clogged, causing some misfires and vibration. You can use something like Techron fuel injector cleaner to try to remove the deposits.
  5. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    Well ive owned it for past 70k miles and ive used only tier1 mostly shell in it. never put any low quality gas ever. checked the air filter in engine cleaned it with air, changed the cabin air filter about 30k ago.
  6. JC91006
    16,482
    8,400
    What year? How many miles on it? How long have you owned the car? A misfire would produce a DTC code. How long have you noticed this?
  7. JC91006
    16,482
    8,400
    You can try cleaning the throttle body and the MAF sensor.
  8. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    this is 2010 prius IV, bought it at 70k and right now it has 140k. since ive owned i put only mobile 1 0w20 oil and toyota AT oil for CVT. no DTC codes and ive been noticing this vibrating for last about 15k miles. i was driving 1000 miles a week so that is like 3 months ago when i started noticing it. and vibration is considerably loud.
  9. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    is there any DIY for cleaning throttle body and maf sensor?
  10. JC91006
    16,482
    8,400
    Since you've only been doing oil changes and transaxle fluid changes. I think you are due for some maintenance.
    1. change your spark plugs
    2. clean throttle body
    3. clean maf sensor (same place as throttle body)
    4. change engine and inverter coolant
    #1 and #2 will hopefully resolve your issues. If you happen to have a faulty ignition coil and/or bad injectors, that could be the cause of a misfire as well.
    Maybe you can take it to a mechanic to look at it? A misfire is very easy to detect.....even without techstream.
  11. xliderider
    7,869
    3,116
    Honolulu, HI
  12. mrbigh
    3,686
    699
    Long Island, NY
    Have your vehicle diagnosed at a reputable repair shop, yours doesn't seem to be a Toyota Stealership issue. In short and with the proper tools, a seasoned mechanic will tell you the car's faults
  13. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    I have not had it diagnosed anywhere yet, was trying to figure it out on my own first. but yeah i am definitely not going to stealership.
  14. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    thanks for the link, looks like that is hat causing the issue, will give it a try whenever i have some free time.
  15. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    This is how bad the vibration is
  16. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    any feedback on the sound if it is misfire or just needs air filter or manifold cleaning?
  17. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    so i took everything apart finally and now i see there is really bad carbon deposit. ill post pics in a lil bit
    now what should i use to clean that carbon deposit and while i was unplugging the coolant pipe, the coolent gushed out and went into that valve which rotates at 90degree. i dont know if that is something i should be worried about.
  18. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
  19. Umar Ali
    Umar Ali Member
    274
    91
    Dallas, TX
    i posted all these pictures for the reference if someone comes across same problem. i found it in another thread that the carbon buildup is what is causing vibration and drop in mpg.
  20. JC91006
    16,482
    8,400
    Throttle body cleaner will clean up carbon deposits
    Umar Ali likes this.
