height adjustment
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by xchrisssiiex, Feb 5, 2013.
  1. xchrisssiiex
    xchrisssiiex New Member
    Sunny Southern CA
    Only had my Prius C3 for 3 days and since day one the height adjustment lever has been giving me problems. it's not making my seat any higher, which is pretty annoying because I'm short.
    anyone else have an issue with the lever?
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    If its only 3 days old & since day 1 it hasn't worked right u should take it back to ur dealer & get it fixed.
  3. X HCH2
    X HCH2 Member
    119
    38
    Upstate SC
    Maybe it's all the way up.
    X
  4. Ashley7
    Ashley7 Active Member
    545
    222
    Oregon
    2019 Prius
    Maybe you're not as stupid as me, but I found that I had to pull the lever a lot harder than I originally was :) If that doesn't work, and you're sure it isn't all the way up, take it to the dealer.
  5. AutoMo
    AutoMo Junior Member
    61
    33
    Eastern WA
    Maybe you could test the mechanism by pushing it down to see if the seat lowers. If it lowers it's working, once lowered you can jack it up, when it stops going up you maxed it out. If down doesn't work either - Stealership time...Good Luck.
