Height Differences Between Infotainment Screens?
Discussion in 'Prime Audio, Electronics, and Infotainment' started by ramolnar, Feb 25, 2021.
  1. ramolnar
    ramolnar Junior Member
    38
    24
    Tucson, AZ
    Recently I test-drove a 2021 Prius Prime LE and a 2021 Prius Prime Limited. On the limited, the larger screen seemed to drop down further and my knee bumped the unit, but there was no knee-bumping on the LE. This might have been just perception, though. Are there specifications on the physical casing size of the two units? Or has someone with both measured knee room differences?
  2. Tideland Prius
    16,627
    I haven't done any actual measurements but based on the photos, there is a difference in height of the MFD between the 7" and the 11.6". I noticed it in the official Toyota photos when the shifter on the 11.6" screen appeared to be lower than that of the 7".
    ramolnar likes this.
  3. SciRunner
    SciRunner Junior Member
    48
    23
    Charm City, USA
    The HVAC center vents on the XLS/Limited are on the side while the LE is on top of the HU. The difference in duct work and HU size could be the reason why you knee bumped the center stack vs the LE. You may have more options later down the road to swap out the LE HU than the XLE and Limited.
    The XLE and Limited HU is not Android Auto compatible.
  4. MTN
    MTN Active Member
    306
    276
    SB, CA
    For the cheap/base model, the LE has "features" that the other trims don't! :D
    Tideland Prius likes this.
