Hello -- an Introduction
Discussion in 'Generation 1 Prius Discussion' started by drwhosc, Mar 4, 2025.
  1. drwhosc
    drwhosc Junior Member
    sc
    2001 Prius
    I
    So just want to introduce myself to the forum. I am in Spartanburg SC, and I have a 2001 prius that we got about 12 years ago. Car still runs, but is needing some attention. I hope to start on it soon. Was hoping I can get some much needed advice on this board. I own several Porsches, and do my own work. So used to complex cars. I have found forums to be very helpful to tap into the collective wisdom. Most of the gen1 is in decent shape. the car will act up from time to tame, but I have been able to stumble through it. Just learned that you can't let this car sit.
    Right now, I need to replace the 12V battery and just want to confirm that a 51R is the form factor I need. I did replace the terminals to a lager size several years back. I also was able to swap out the hybrid batter pack with a Gen 2 version several years back.
    the other thing is I was wondering if someone comes across a Gen 1 that they are parting out if they can contact me. I would like to refresh the interior if I can find a good one. I lent the car to a buddy of mine, and i got it back with a paint spill on the back seat. can also use a front bumper.
    I will post a picture in the next day or so. looking forward to this project, adn hopefully I can tap into the knowledge of others in this forum.
    thanks -- rr
  2. Tombukt2
    Tombukt2 Senior Member
    11,994
    2,119
    Durham NC
    I'm over in Central North Carolina they pop up on the marketplace and various and sundry places very regularly and there's a place down in Conyers Georgia or several places that have miles of Prius you'd have to physically go down there sometimes you see them on eBay selling things If you look at the sellers information you'll see quite a few junk yards down in Conyers and you can do some googling and look at some Google maps there's a couple of junkyards down there that literally have miles of Prius old ones that is quite something.
  3. Leadfoot J. McCoalroller
    7,823
    7,289
    Pennsylvania
    2018 Prius c
    @ronlewis is often found to be parting out 1st generation cars, he can probably help you.
  4. Trombone
    Trombone Active Member
    289
    100
    Allentown, Pennsylvania
    2002 Prius
    Correct on the 51R case size.
    A cheaper alternative would be a lawn tractor battery like this one: https://www.batteriesplus.com/productdetails/sliu1rxhd . I have that battery installed in my '02. There are less expensive ones available from the usual suspects. I bought terminal adapters to convert the lawn tractor battery's spade lugs to SAE terminal posts. It's also possible to bolt directly to the spade lugs.
    This battery has given good reliable service for over a year so far, even through a stretch of single-digit low temps here in PA, so it should work fine in SC too. I have hopes that it lasts at least as long as my previous Interstate 12V, which was seven years. We'll see.
    #4 Trombone, Mar 5, 2025
  5. drwhosc
    sc
    2001 Prius
    I
    thanks for the info. Will have to expand my search. Took the car out today. It runs great. Triangle of death is on, so will have to diagnose that.
  6. drwhosc
    sc
    2001 Prius
    I
    Yea that is what I pulled out, Found a lead acid 51R battery at auto one for $80.
  7. jamesprius
    jamesprius Member
    142
    17
    San Jose, California
    2001 Prius
    I
    i think i tried 51R in the past and it was too large you have to bend the supporting metal piece away
    151R seems to fit but has less capacity.
  8. Trombone
    289
    100
    2002 Prius
    51R will not fit the hold-down, but it does fit the available space.
    Never heard of a “151R”.
  9. jamesprius
    jamesprius Member
    142
    17
    2001 Prius
    I
  10. drwhosc
    sc
    2001 Prius
    I
    I removed the hold down and changed the terminals on the cables. The 51R fit like a glove int the space.
  11. Trombone
    289
    100
    2002 Prius
    The U1R lawn tractor battery fits the space, and the factory hold-down too! Can't remember now whether I had to shim the U1R underneath with a nominal 1" thick board, like I did with the 51R. And I sure like the price of the U1R, compared with that 151R linked above.
  12. jamesprius
    jamesprius Member
    142
    17
    2001 Prius
    I
    i think the 151r i got was 109 with a 3 year replacement up to 8 year prorated.
    the 51r seems like better value tho, i think you can get one around the same price as the u1r
    if you happen to know the board measurement, maybe i can try cutting a wood one next time.
  13. dolj
    dolj Senior Member
    8,180
    4,167
    Wellington, New Zealand
    The U1R lawn tractor battery has a much smaller Ah capacity than the OEM AGM or its direct AM replacements.
    These U1R and 51R batteries are all flooded lead/acid, not AGM which is why they're all so cheap.
    It is your car and your money, do what you like.
    #13 dolj, Mar 7, 2025
  14. Trombone
    289
    100
    2002 Prius
    In re: board size, I don’t recall exactly, but it fits the tray there in the wheel well. I just happened to have the right size board on hand from a previous project (call me lucky), so I didn’t even have to cut it to fit.
    The U1R doesn’t weigh as much as a 51R, and that’s a help for me now in my dotage, trying to wrestle a heavy chunk of a battery into that tight space.
    jamesprius likes this.
  15. KitsuneVoss
    KitsuneVoss Member
    291
    44
    Virginia
    Is it okay to use a non AGM battery?
    I can get a U1R at Walmart for $30
    Posts are even in the same positions
  16. ronlewis
    ronlewis Active Member
    971
    194
    texas
    2001 Prius
    I just use whatever to prop the U1Rs up - newspaper, cardboard, etc. Or even put cardboard on top, under the hold-down bracket. I just charged one up this week that was in a car that had been sitting for more than a month. It recovered and has lasted a couple of days so far w/o problem. The mfg date on it is 2/24, not sure when I bought it. Just that it's lasted more than a year for $30 is pretty good. But that 3-year warranty on the other battery sounds good at that price. I like the WM batteries because I travel a lot and could always find one. But they reduced the warranty from 6mos down to 1mo last year which reduced their value. I could always exchange them for free before 6mos. but no more.
  17. ronlewis
    971
    194
    texas
    2001 Prius
    I do have some seats in good shape if anyone wants to pay shipping from Houston. If you're close to a major city, you might get someone on UShip to carry it cheap if you don't mind waiting for delivery.
