Hello and a question about Prius touring
Discussion in 'Newbie Forum' started by Illini, Dec 25, 2008.
  1. Illini
    Illini New Member
    Champaign, IL
    Hi!
    We just bought a 2009 Prius Pkg 2 Touring. After reading on the forum, I really wanted to buy winter tires. But the touring edition tire size is really odd, and everywhere online is out of stock.
    More alarming was when I called local places, they told me they don't stock that tire size, EVER. And we are in one of the larger towns in our area.
    My husband will be using the car to commute 200 mi twice weekly. I'm concerned that if he ever had a flat, the car would be stranded until the tire could be special ordered. Am I just being paranoid? Or does anyone carry a full-size spare for their touring? Or use ROF tires?
    Any advice is appreciated :D
  2. spitinuri
    spitinuri Member
    317
    You might buy a second set of wheels (standard size) and mount your winter tires on them then you only have to change wheels with the seasons.
  3. Santiago
    Santiago New Member
    109
    New Mexico
    195x55x16's snow tires (e.g. X-Ice and Nikion WRG2) are special orders out of Denver every where I've asked in Albuquerque. You might want to start the process of getting winter tires even though part of the winter season is gone. Reading in the forum, it would appear that BRAND NEW OEM Touring Tires are probably OK in the snow but you wouldn't want to plan on using them beyond the remainder of the current winter season. Next snow I am going to take mine out and see if they are usable in their current state (3,000 miles).
  4. Boo
    Boo Boola Boola Member
    5,051
    485
    97
    Flushing, NY
    I don't have a Touring, but from what I've read on this forum (and I believe I've read every thread and almost every post about the Touring), I know of no one who carries around a full size spare in the Touring OEM size of 195/55/16. Everyone just lives with the donut spare. But because there are very few non-runflat tires available in the OEM size, when Touring owners want a complete new set of tires -- be they all season, snow or other tires -- I've seen a lot of Touring owners go with the very popular and standard 205/55/16 size, in which there are A LOT of different tires available.
    One thing I would suggest is to get a can of the current formulation of Fix-A-Flat. It's now been formulated to be safe to use with cars or wheels, like those on the Prius, that have a tire pressure monitoring sensor/system.
  5. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    did you try tirerack? i see a dunlop sp winter sport 3d run on flat tire in stock for 109 a tire.. i thought they had more winter tires but now i just see that one.
    sears has the winter sport m3 for 131. i do not know if thats the same tire
    i used to see like 3 or so winter tires for that size. i wonder if they still make winter tires in that size
  6. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    The touring can use the standard 15" wheels without a problem. I ordered standard 15" steel wheels with Blizzak tires from Tirerack.com Except for not having the air pressure sensors on them (which causes the low air pressure light to be on) it works fine. In general it's actually better to have skinnier tires in snow and ice anyway, so skinnier 15" wheels with non-touring sized tires is a good plan for snow. Plus it means that you don't need a tire shop to unmount and remount your tires every winter.
  7. rigormortis
    1,340
    26
    san jose, ca
    yeah that would be a good suggestion
  8. Neicy
    Neicy Member
    834
    Wakefield, MA.
