Hello from east Tennesse
Discussion in 'Newbie Forum' started by SparkyHiker, Dec 14, 2012.
  1. SparkyHiker
    SparkyHiker Junior Member
    2001 Prius
    I
    Just joined the forum. I've had my Gen I for about 5 years. It's got 150k on it and the battery is starting to give me trouble. It's been a great car. This and the rear hubs are the only problems that I've had with it. Found this forum while doing my research on what I need to do to rebuild the battery. Looking forward to learning a lot more about my car.
  2. usnavystgc
    3,159
    990
    Tucson, AZ
    Welcome to the forum.
  3. Chris S
    Chris S Active Member
    323
    109
    Gilbert, AZ
    I think you'll find this forum to be really helpful. I started on it after Googling some stereo info and now am hooked. So many cool and helpful people.
    I've heard the batteries are good for about 6 years. Now it sounds true :-( Looking forward to hearing how it all works out
    51,141
    sounds more like eleven years! not too shabby. welcome sparky, all the best with your rebuild!
  5. phickson
    phickson Tron Pod Occupier
    89
    31
    Maryland
    Check out the You Tube video - search on You Tube look for Toyota Prius battery removal and repair - 9:38 mins in length.
  6. SparkyHiker
    2001 Prius
    I
    Is there a specific Gen I forum? I'd like to post specifically in that forum if possible.
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I
    It's a subsection of the GenII forum.
  8. SparkyHiker
    2001 Prius
    I
    The battery rebuild is complete. The main problem seemed to be either the corrosion on the terminals or the min/max module voltage. I cleaned up the connections and shuffled the modules so the module pairs all have the same voltage. They really weren't that far off from each other so I thought matching them up would keep the computer from flagging an error. Interesting thing was the modules in the center had a slightly lower no-load voltage than those on the ends. My guess is the center is slightly warmer so the degradation is worst there. It's raining right now so I'll have to wait for better weather before trying the whole thing. Something about working with 300v in wet conditions makes me nervous even with the safety plug pulled.
  9. rico567
    rico567 Junior Member
    Central IL
    While the repair itself is straightforward enough, and the person who made the video puts very good caveats in there, it cannot be emphasized enough that working with several hundred volts DC at the kind of current that battery can deliver is probably NOT for people who lack the proper background.
  10. SparkyHiker
    2001 Prius
    I
    Put the car back together and it works just fine. I ran it hard and never saw a problem at all. It will be interesting to see how long it lasts. I'll keep ya posted.
  11. usnavystgc
    3,159
    990
    Tucson, AZ
    Good job Sparky. Thanks for keeping us posted. I love to hear success stories like this. I just hope you continue to have success.
