Hello from The Netherlands
Discussion in 'Newbie Forum' started by ginkelvanmichiel, May 7, 2023.
  1. ginkelvanmichiel
    ginkelvanmichiel New Member
    Netherlands
    2001 Prius
    I do not own a Prius yet, but because I like to work on cars as a hobby, I might buy a GEN 1 tomorrow. It has some issues, and this forum seems to hold enough knowledge!
  2. PriusCamper
    PriusCamper Senior Member
    12,058
    4,893
    Pacific Northwest, USA
    Maybe hold out for a Gen2, they have less mechanical issues and more abundant cheap parts... Lots more repair info on here for Gen 2 too.
    51,141
    consider getting tech stream for all the computers. good luck!
  4. ChapmanF
    17,328
    I liked my Gen 1 and I miss it. But they did make a number of improvements in the later generations.
    The Gen 1 had many sensors made of ordinary potentiometers that would become noisy after a while, leading to various classic symptoms (search for "big hand syndrome", "steering gear jitters", "mouse in the heater", and so on). Toyota started right away in the next generation replacing most of those with non-contact, inductance or Hall effect sensors to avoid those kinds of symptoms.
    Gen 1 also was the only generation with a belt-driven A/C compressor. The air cooling only works when the engine runs. If you are sitting in traffic in hot weather, the engine will be frequently cycling on and off to run the compressor. All later generations have an electric compressor, so the engine can stay stopped and the A/C continues to work.
    Also, all the later generations have the hatchback shape, more versatile for cargo, and comfortable enough to sleep in (popular for camping, given the way the heat and A/C can work without the engine constantly running).
  5. JohnnyPR
    JohnnyPR Member
    96
    25
    Hinesville, GA
    Welcome and good luck finding a nice Prius project
