HELP! 12v battery parasitic draw not in any fuses
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SierraRios, Dec 6, 2020.
  1. SierraRios
    SierraRios Junior Member
    San Diego
    2022 Prius Prime
    HELP! I have a parasitic draw on my 12v battery of ~90 ma but I realize the resting current draw should be closer to 20 ma. When I have a multimeter in series and remove each fuse in the fuse boxes (engine compartment and under instrument panel), I can only determine three fuses that result in a total draw of 10-20 ma in resting state [fuse 12 (ACC-B), 28 (H-LP HI RH), and 39 DOME]. I cannot determine where the remaining ~70 ma draw is coming from. Are there other circuits that are not on these two main fuse boxes? How else can I determine where this draw is? I pulled many relays as well (no effect) but I assume those should just be embedded in the circuits with fuses.
    BACKGROUND: I have known that the 12v battery in my Prius had an appreciable resting state current draw since I got it 4 years ago because the car would go dead when simply parked for >1 week. I thought it was just the way Prii (Priuses) operated. Part of the problem is that I'm an occasional driver (avg <3000 miles/yr) as I don't have a commute and am away a lot (I work internationally for 2-4 weeks at a time). An initial attempt to jump start the car with my truck battery was disastrous and blew some fuses, but all was restored by a specialized Toyota mechanic (TLC here in San Diego). Since then I realized that special jumping was needed and I bought and used a Suaoki 12 amp-hour external electric jump starter whenever I needed to jump start the car. I also bought a Black&Decker 3M3B battery tender but didn't use it very often (car is not garaged). I addressed the issue of the car being parked long spells by disconnecting the 12v battery in the back when I would go away for more than a week. I replaced the 12v battery sometime in 2016 soon after I got the car with an equivalent AGM Optima from Napa (I also had fixed the hybrid battery). However, unfortunately I let that 12v battery go through several discharging cycles, and I had to replace it in 2017 (under warranty). More recently I replaced it with an OEM TrueStart battery from the Toyota dealer (about 5 months ago; ~$260). Around that time I also bought a 20W 1.3a solar trickle charger which has generally maintained a good charge state on the battery even when parked for long periods of time. Recently with less sunlight as I was occasionally checking the voltage of the 12v battery, I've noticed that even with the daily solar charging, the 12v battery was slowly declining in voltage - such as morning readings of 12.40v, then 12.35v, then 12.30v, down to 12.2v (I charged up with the battery tender at that point). I realized from this forum that it seemed it the 12v battery was dying too quickly in the resting state so I decided to try and figure out if and what the parasitic draw was, and address it.
    CURRENT DRAW MEASUREMENT: I disconnected the 12v battery and hooked up a multimeter tool to the negative (black) lead in series, and measured a ~0.09 amp current draw when car was at rest (>5 min no disturbance except hood open; key >20 ft away; doors unlocked; but I noticed that locked doors didn’t have any effect). Actually it would vacillate sometimes between 0.08a and 0.09a (or the following day from 0.09a to 0.10a). When a door is opened, the current draw goes up to ~1.9 amp, then starts to go down some, staying at ~0.7 amp and remains there presumably from lights being on. If the door is closed immediately, it remains at ~0.7 amp for 10-20 sec, then goes down to the original resting level (0.09 amp). If I approach the car with the fob, the current draw sometimes goes up to ~0.65a. Locking or unlocking the doors brings a brief (~100 ms) current draw close to 10 amp but the multimeter handles it without wrecking (the max the multimeter can sustain is 10a). Having the voltmeter connected does not appreciably affect current draw (it stays ~0.09a). The TrueStart battery capacity is nominally 45 amp-hours and it's only ~5 months old, purchased from a Toyota dealer. So theoretically with a 0.09a draw, it would drain 1 amp-hour every 11 hr or so, or about 2.3 amp-hours per day, and would take ~9 days to discharge 50% and 18 days to completely discharge. However, I've noticed sometimes that the voltage drops from 12.7v to 12.4v overnight which suggests maybe the capacity of the 12v battery is not the full 45 amp-hour or that there is some other drain on the battery at night.
    FUSE CHECK: I kept the current at the stable ~0.09a parasitic draw and pulled individual fuses to determine which circuit affected the current. There are 2 fuse boxes: one in the engine compartment and the other below the steering wheel on the left. When checking the latter, the doors must be closed and someone reading the multimeter when pulling the fuses (my wife helped with this). I used needle-nose pliers to pull each fuse and see the effect on the current reading going through the multimeter.
    Pulling most engine compartment fuses has no effect except the following:
    FUSE 28 H-LP HI RH (right headlight/highbeam): changed multimeter reading to ~0.08a (maybe drawing up to ~0.005a)
    FUSE 39 DOME (audio, smart key, interior lights, luggage light, clock): changed multimeter reading to ~0.08a (maybe drawing up to 0.01a; also noted that when reinserted this fuse, the current went up from 0.08a to 0.13a, then settled to 0.09a]
    FUSE 12 (ACC-B Power Outlet; “ACC” fuses): assumed multimeter reading slightly down; the current goes up to 0.11a when this fuse is reinserted and may drop almost imperceptible when removed
    SO WHERE IS THE PARASITIC DRAW OF ~70ma? What else can I check to determine it?
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,830
    Clearwater, Florida
    Who is going to read this long of a post?
  3. SierraRios
    San Diego
    2022 Prius Prime
    Good point. Is there a way to edit or delete? [I can repost just the first part]
    edthefox5 likes this.
    51,085
    tl;dr, what post?
    might be best just to put in a 12v switch.
  5. rjparker
    rjparker Tu Humilde Sirviente
    9,564
    5,872
    Texas Hill Country
    I will read it.
    So you have measured 70 ma when all three identified fuses are pulled?
    It is conceivable the extra 70ma is flowing through fusible links to loads with no removable fuses. It looks like the Electric Power Steering ecu gets power through its fusible link without a removable fuse. The Headlight ecu has connections through a relay without a separate fuse.
    Maybe some unintended current path was created after the reversed jump. There could be some cable or fusebox leakage current to ground.
    #5 rjparker, Dec 7, 2020
    SierraRios and SFO like this.
  6. SierraRios
    San Diego
    2022 Prius Prime
    Thank you so much for the reply to my long initial post! To respond, if all 3 of those fuses that I mentioned are out, there is still a current draw of 0.07-0.08a. I appreciate the suggestion that some other circuits without fuses could be the culprit. I was looking into the fusible link block as a potential culprit and may try to pull that out. My diagram shows it by the 12v battery. I also appreciate the circuit diagrams. [I do need to review the diagrams more closely] Do all these other circuits go through the fusible link block?
    I also realize that there may be some unintended current path. That seems like it might be harder to determine/locate. But just FYI - the car wasn't reverse jumped, I think the amount of amps that went into the circuitry from my truck battery (I connected it to the 12v battery and not the leads under the hood) were too high and fried some of the fuses. Apparently that's why they say never jump start a Prius from a regular car. Regardless, there might have been some melting of something and current leakage due to it. I'll try some to diagnose some more and report back.
  7. SierraRios
    San Diego
    2022 Prius Prime
    I also realize there is another "fusible link" in the engine compartment fuse box - something I didn't check yet. I saw a thread here about removing and replacing that - sounds a little involved. I'll try to disconnect that as well to see if it's the source of the ~70ma current draw.
    The "fusible link block" on top of the 12v battery is easy to disconnect the wires from.
  8. rjparker
    9,564
    5,872
    Texas Hill Country
    The battery fusible link is separate from the engine fusible link module. Jumping from a high amperage truck battery will not cause damage. The current is limited by the load as long as the jump is connect in the correct polarity. If damage was done it was either reversed leads (common) or extreme over voltage (like a 24v battery, uncommon). Reversed leads often blow fuses and eventually the car runs again. Sometimes it will cause more damage.
    The engine fusible link block has multiple fusible links built into the single module. It feeds everything so taking it completely out proves little. Some of the feeds just go through a buss bar to the adjacent fuses. However there are cables off of the module feeding fuses and other things that could be removed one by one. If you look at the drawings I marked up, one of them shows all the fusible links in that engine module. Most have downstream fuses so if you pulled all the fuses they are not serious suspects. But two do not.
    Here is one of the diagrams with more text added:
    0D373DB5-C857-4C8F-BB77-ADB955A6D24C.jpeg 05D6C79A-491A-4A07-85D3-9282CDC71FE0.jpeg
    #8 rjparker, Dec 8, 2020
    SierraRios and bisco like this.
  9. SierraRios
    San Diego
    2022 Prius Prime
    Thank you for more input. You may be correct that I did a reverse polarity jump. The truth is I don't remember exactly what happened as it was 4 years ago. I looked at the TLC mechanic receipt to remind me - it says that I reported the car wouldn't start but radio turned on, so I tried to jump it under the hood and at the battery terminals, but during one of those jump attempts the jumper cables got very hot so I stopped (I recall the plastic coating on the jumper cables melting!). The car was completely dead, and then I was quite happy when the mechanic easily fixed most problems by replacing 2 fuses and the "fusible link block" (a $260 job). [I think he probably meant the "fusible link module" in the engine compartment?]
    I did pull those connectors coming from the fusible link block by the 12v battery. With the big one pulled, all current went to zero. I realized this is expected since all circuitry powered by the 12v battery goes through that connector.
    I then went to disconnect the fusible link module located in the main fuse box in the engine compartment (photo). When I disconnected the main wire into it (located just left of and closer than the red cap for jumping access - it's the one with the big metal loop), I saw that the current went to zero. I initially thought this narrowed the current draw to the fusible link module, but current went to "0" and not to 0.02a, so I suspect some current going to the rest of the fuse box is passing through that wire.
    In addition to the main wire at the top left side, there are four bolted wires on the sides of the fusible link box and other wires connected on the bottom. I'm trying to get the module out to disconnect these one by one but I'm having a tough time getting the connected black fuse box part out as well (stuck at the closer/bow part of the black box). Seems like it might be difficult to pinpoint it further within the fusible link module. I might be able to disconnect some of the bolted wires but it's not clear all the fusible links they connect to.
    #9 SierraRios, Dec 8, 2020
  10. rjparker
    9,564
    5,872
    Texas Hill Country
    The wire you disconnected at the engine fusible link is the main feed from the 12v battery. The fact it went to zero just means the cable back to the battery is not leaking current.
    To get the module out you should disconnect the bussbar feeding the adjacent fuse holder. At this point you have removed many fuse loads. Then it will come out far enough assuming all of its tabs are released. There are a couple of plug in cables on the bottom of the fusible link as well.
    At least you will be able to change your own fusible link "block" in the future if needed.
    Please realize you are getting into advanced electrical diagnosis. Most would want a good grasp and access to all of the detailed wiring diagrams. Some of that requires the Toyota Information System TIS, which is affordable and gives you downloadable pdfs. However it is hundreds of separate drawings with many links within the documents that only work when you are within the paid period. Plus they are not strong on theory or sequence of operations since they are written for certified Toyota techs. Nevertheless you can probably find the offending subsystem doing what you are doing. The fact that it was not a load controlled by ordinary fuses makes it more challenging than normal.
    https://techinfo.toyota.com/techInfoPortal/appmanager/t3/ti?_pageLabel=ti_whats_tis&_nfpb=true
    #10 rjparker, Dec 8, 2020
    SierraRios likes this.
  11. edthefox5
    10,096
    4,830
    Clearwater, Florida
    They sell the G2 Prius Electrical diagram book on ebay for like $40 sometimes alot cheaper. If you plan on owning this car for a while I highly recommend it. Its a must.
    I would not think about a deep dive on this car without it. But many do....
    This one: The Bently is excellent too way more inclusive but twice as much.
    2009 Toyota Prius Electrical Wiring Diagram Service Manual | eBay
  12. SierraRios
    San Diego
    2022 Prius Prime
    Thank you RJParker for all the informative help! I got the fusible link module disconnected from the black fuse box buss bar. Without pulling out the black fuse box part entirely, I was able to lift out enough of the fusible link module to remove three of the more easily accessible cables that were bolted to the box (two on driver's side between the two tabs, and the one on the passenger side). I determined that through those cables there was probably ~15 ma draw since the current from the battery dropped to a stable 0.08a from 0.09-0.10a. I didn't determine which of the three its was coming from. I figured this was an insignificant parasitic load - I was still looking for the 70ma draw.
    I also realized that the buss bar to the fuse box passed current that controlled the locks and some other functions. My fob key would not work to lock or unlock. I actually had to push down on the back hatch to close it enough to get the stable lower 0.08a reading from the multimeter in the back.
    I was about to give up, but gave another shot at getting the black fuse box part out and eventually did. With that out, I could lift out the whole fusible link module. The difficulty stemmed from the black fuse box staying attached at its front part - I couldn't figure out where the tab was that was holding it in. Eventually I did - the tab is hidden down under, around and in between what look like the two black tabs there - and you have to push it in from an awkward position. I was then able to remove the fourth cable bolted to the fusible link box, which I determined had no effect on the ~0.09a current.
    I was going to pull the whole fusible link box out and then pull each of the inserted bottom cables, but I would have had to remove all the bolted wires again and it just seemed like it wasn't going to result in very useful information for me. I suspect that ~70 ma draw is from some of the bottom cables coming out of the fusible link box. I assume you can tell from the wiring diagrams what those bottom cables lead to? I'm just curious what it might be - could possibly motivate me to take them out or to assess the systems powered by them. Having gone through removing and reinstalling that fusible link box is something good to know. And although it would be nice to resolve this issue, you're right that it seems to be getting too involved to chase down - just to resolve a relatively low parasitic draw that I have lived with for many years now and can until I sell the car. [I'd love to upgrade to a Plug-in Prius].
  13. SierraRios
    San Diego
    2022 Prius Prime
    Also, as a note to EdTheFox and others, I found a great 467-page document of the entire detailed circuitry of the 2nd gen Prius online at:
    http://www.selidori.com/tech/00000-04999/337-aBgux.pdf
    For removing/changing the fusible link module, there is a good post with photos here on PriusChat and also a video on YouTube:
    How to change Fusible link under hood | PriusChat
    [A final note - although I took electromagnetics in high school and college physics, I'm no electrician and it still seems pretty complicated to understand where all the circuits connect - unless you really know each symbol by heart and can figure out easily to/from connections not shown on the page]
    Many thanks to all contributing to this forum and special thanks to rjparker and edthefox here for the guidance.
    OBJUAN likes this.
  14. rjparker
    9,564
    5,872
    Texas Hill Country
    Here are three screen shots from the wiring pdf you now have. The left side shows the fusible link and the wire codes for the bottom cables. Then you search the document for the individual load circuits.
    As an example, I searched for 50A EPS and found about eight pages. The best was the diagram on the right showing how the 50A EPS fusible link powers the electric power steering.
    As mentioned earlier, most loads can be eliminated since you pulled relays and removable fuses. In this example, there are no removable fuses or relays in the circuit. There may or may not be other candidates.
    #14 rjparker, Dec 8, 2020
  15. rjparker
    9,564
    5,872
    Texas Hill Country
    While we are talking parasitic draw, a new video by South Main Auto's Eric O shows how he proceeds. While his problem is different, notice the steps and tools. Another really good electrical/control guy is Ivan from "Pine Hollow Auto". Both are excellent, Eric is older and self educated in advanced diagnostics while Ivan is younger and a degreed engineer. Both get work from other mechanics and dealers when the other shops give up.
    South Main Auto ("current" video - get it?)
    Pine Hollow Auto Diagnostics (older video)
    Be sure to wait for the bonus footage on his videos
