Help 2007 toyota prius
Discussion in 'Gen 2 Prius Technical Discussion' started by Jpepsi, Nov 30, 2015.
  1. Jpepsi
    Jpepsi New Member
    Eastbay to sf
    I had my Prius check out and gave me these trouble codes couples battery's low he has a red triangle
    P0A78??
    P3000
    P0A80
    P03014
    P0315
    The battery's rating 13.5 volts
    Will always trouble codes go away after replacing the battery I added inverter to it because it was it was dying after 50 miles per hour then it slowed down??
  2. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The battery codes are about your HV (Traction) battery, not the 12v battery. There are many threads discussing your repair options, but it does run into the low 3 figures ($) to do a repair.
    13.5v is when the 12v battery is charging; to tell if the 12v battery is still good, you need to test the resting voltage (when the Prius charging circuit is not active - it should be about 12.5v - more if the battery is new) and under load (again with the charging circuit inactive - it should stay above 12v).
    JeffD
  3. Jpepsi
    Jpepsi New Member
    Eastbay to sf
    I add a pice of the. diagnostics menu and report
    49,435
    looks like you need a new hybrid battery. 3-4k new, or get a rebuilt doorman of $1500.
